The problem is you don't know how many units Oratory has averaged, which could vary quite a bit for different models. Yeah I was primarily referring to the fine grass variations as I said in my post. Note though by 'environmental noise' I'm not only including things like
instrument fan noise (which can have a
significant effect on the measurements), but also acoustic crosstalk from one channel to the other during the measurement (when stereo sweeps are used, as they are on this site), which could result in comb filtering and so 'jaggies' in the measurements (lower Q than the fine grass noise). HifiMan headphones not only have among the least noise isolation, but also the
highest sound leakage, with the Arya leaking 72 dB at 1 ft with a 100 dB signal according to Rtings' measurements (compare that with 60 dB leakage for the HD650 for example). So HifiMan headphones will exhibit more acoustic crosstalk than other headphones (which it could be argued is actually a good thing, as crosstalk occurs in speaker playback, which most music is mixed and mastered on and for). When you look at other planars also with low isolation and high leakage they show
comparable jaggedness. And it's not just planars either, but dynamic driver headphones with poor isolation and high leakage
too. Unless acoustic crosstalk as well as more general environmental noise are controlled for by measuring with individual channel sweeps and acoustically isolating the measurement rig, conclusions that HifiMan (or planar) headphones have inherently more jagged frequency response than other headphones are invalid.
