Hidizs S9 Review (Headphone Adapter)
ZolaIII
Can you recommend a particular product?
Any with such DAC will do good regarding power consumption but if I must I sow old Tempotec Sonata HD Pro (Hidizs S8) back in stocks with full cable bulk (including for iPhone) simply because it's still not too pricey and works good. Which ever you can find from those two (as it's really the same with different shell and better on Hidizs S8) for less money. Implementaed volume steps on dongle are too big but it works in combination with smartphone controls good enough.
Thanks. With the phone on Low Power Mode the S9 Pro battery drain is very tolerable for me. Micro USB on the ones you recommend is a bit of a step backwards but I guess it doesn't really matter.
The CS43131 is still most power efficient DAC with proper 2V unbalanced output (and very EMI immune). We will hardly see future improvements regarding efficiency without implementation of USB audio 3.0 specification.
There are some very cheap no-name brands on Ali Express that use this chip. Would it be a mistake to buy one of them?
ZolaIII
There are some very cheap no name brands in Ali Express that use this chip. Would it be a mistake buying one of them?
Probably not it's very resilient chip (EMI rejection rate and all in one IC DAC and amp) and I am not aware of any really bad implementations of it (there were some cases of bad firmware iBasso as much as I recall that they didn't ever corrected for some dongles). On the other hand aim for one's with detachable USB (OTG) cables as that is in generally greatest problem regarding all of dongle DAC's.
Thanks very much
totti1965
Bonn / Germany
Perhaps this was asked earlier, but I ask myself if it is possible to use it also with an iPhone with an Lightning to USB-C Adapter. Or is it Just for Windows / Android Ecosystem and perhaps Apple Desktop Computers?
Mulder
Gothenburg, Sweden
I use it with a an iPhone and a Lightning to USB-C adapter. No problem. Well, there is a problem, but it has nothing to do with the adapter. I think it drains the battery to much to be really usable with a cell-phone.
totti1965
Bonn / Germany
Thank you!
Good to know!
Sonic-Wall
Dosen‘t work with the Fiio LT-LT1 Type-C to Lightning OTG cable!
Even my S9 pro is recognized by the Qobuz app and the colors are changing according to the sampling frequency of the songs no music comes out of this thing! The same cable on my Qudelix works like a charm With my iPhone 13.
Obviously there is a bug in the Hidizs S9 Pro!
JamesYeomans
My original S9 worked fine with iPhone 13 Pro Max using the official Apple camera kit.
GatorZ
I have the same issue. I also own a Fiio USB-C/USB-C cable and this one every works fine (on android phone). Then why does the Fiio Lightning/USB-C not work properly ? No enought power ? Works with my BTR5 but this dongle has a battery.
Sonic-Wall
After the Fiio cable didn‘t work, I‘ve bought the Hidizs LT02 USB-C to Lightning Cable, which of course worked with my S9 Pro fine.
Then I tried the Hidizs cable with my Qudelix and it also worked. BTW: Qudelix does also have its own battery.
Obviously either Fiio or Hidizs deviate from the spec…
john11
Would the s9 work well with a streamer? I have a zidoo z9x pro media player and am using the s9 via the usb port for the audio. Stereo files sound okay, but when using the zidoo to downmix multichannel to stereo the sound quality is poor. Do you think this is a problem with the zidoo more than the s9, have you heard anything
staticV3
The zidoo is doing the downmixing.
If stereo content sounds good, but downmixed content doesn't, then the zidoo is at fault.
john11
Is there a problem within the menus, perhaps one of the settings is wrong. Does the zidoo need anything installed, some kind of codec or software
staticV3
I don't know, sorry.
