SpeleoFool
Just stumbled upon this review. I own an R6 Pro (stainless), which I bought to compare with an Opus #2; both were well-regarded and at similar price points.
I'm a little surprised to see such terrible measurements since, subjectively, I found this to be quite a decent player. Granted, there are many angles to what makes a DAP "good," including convenience features that might not be the best in terms of sound quality, but nevertheless add value by expanding upon the basic capabilities of a player.
As a rule, I've always considered USB input / DAC mode as a secondary (convenience) feature for DAPs like this that have a screen + touch mode. If a portable USB DAC+Amp was the most important use case for me, I'd look more toward something like the Topping NX4, which does that and only that. On a device like the Hiby (with a touch screen + dedicated software and settings), I expect the primary use case will be one of two things:
1. Some models lean more toward offline play, offering plenty of storage for large libraries of FLAC / DSD / other hi-res music files
2. Some models are geared more towards online streaming, with support for services like Tidal, Qobuz, etc.
The R6 Pro is actually good for both cases. Native Google Store support makes it trivially easy to install a variety of popular music apps, and the Hiby manages audio settings across any apps you might wish to use. The native music app is decently fast, capable and easy to navigate.
In any case, it's not unusual (in my experience) for a USB connection to screw with sound quality out of a DAP like this. Mostly this is a concern when trying to charge and play music at the same time, but I really wouldn't be too surprised if that might be a factor for some DAPs being used as a DAC/Amp as well. While it's disappointing to see poor measurements here, that's not a make or break use case, at least for me.
One other data point: the R6 Pro is sensitive to RF noise; if my cell phone is too close, I'll get audible artifacts out of the balanced output. Keep interference sources away and it's got a pretty black background. Not sure if that could have been a factor during measurements, but it is a flaw in this player. Personally, I find it a minor annoyance that's not a total dealbreaker, but it's something to consider when you've got players like the Fiio M11 Pro at the same price point.
