I have been reviewing some of the links provided by BooBoo, taking notes, and then preparing segments to add to my white paper. This is the latest that I have come up with:
Headphone sources, such as mobile phones or dedicated headphone amplifiers, exhibit an output impedance. The differences in these source output impedances is a very common reason the same headphones can sound different, depending on the source used to power the headphones. Regrettably, the output impedance of sources is not often specified by manufacturers; yet it can significantly affect sound quality and is a key parameter that determines the compatibility of particular headphones with the source. A source output impedance under 2 ohms will work well with nearly all headphones on the market.
In audio systems, including those with headphones, the damping factor is ratio of the resistive portion of the speaker impedance to the resistive portion of the source impedance. Higher damping factors are preferred, and the damping factor should be taken into consideration when choosing the combination of source and headphones that vary widely in impedance, typically in the range of 16 Ohms to 600 Ohms. There are three primary reasons for choosing a source with low output impedance:
• The greater the output impedance of a source driving headphones, the greater the voltage drop when driving headphones with low impedance loads. If this voltage drop is too great, the low impedance headphones cannot be driven to appropriate listening volume levels.
• In many cases of headphone design, the headphone impedance changes with frequency. If the source output impedance is too high, then the voltage driving the headphones will likewise be frequency dependent. Thus the greater the output impedance of the source driving the headphones, the greater deviation in frequency response affecting tonal balance.
• Electrical damping is reduced as the source output impedance is increased, and this can result in subpar bass performance of the headphones, with boomy (less controlled) bass sounds. Additionally the transient response is compromised and the bass will roll off sooner and not go as deep.
Regrettably, the only Standards for source output impedance are severely out of date and inappropriate for modern headphone sources.
Question: So if the manufacturers often don’t provide output impedance ratings for source amps, where is the best place to look for such information? The list provided will prove helpful, but are there other sources? Is this something an amateur equipped with an electrical meter can measure easily?
