solderdude
I read a couple of times but don't understand your point here. Are you saying emf damping is valid or not?
For headphones the damping factor is nonsense. Voltage division is the culprit of the change in sound when the impedance varies.
You have seen the math and impedances involved.
Do you happen to have an stepper motor at hand? If yes, try to turn it with open wires and than with shorted wires. Its getting much more difficult to turn with shorted wires, cause the generated voltage is shorted and you get an current flow acting as brake.
Let me ask you to measure the DC resistance of the stepper motor windings... Then you'll understand why the stepper motor is damped so well. Also the way the coils are layed out in the motor have something to do with that behavior.
This is the same effekt you will have at your speaker. Shorting terminals will counteract / damping motion of the coil in the magnetic field. This effect is less effective if you not short the terminal but include an resistor. And this resistor is corresponds to the output resistor of the amplifier. The higher the resistor - the less the damping effect.
Read my post again.. this is not about speakers with heavy cones and low resistances. This is about headphones with light membranes that are damped acoustically and mechanically a lot better and do not rely on electrical damping.
And yes, increase of THD is actually increased distortion. Voltage division is linear and doesn't cause distortion. THD is caused by nonlinear transfer function.
How come that when I measure headphones with a microphone and compensated for frequency response and applied amplitude I don't see an increase in THD ?
Did you not understand the principle of THD measurements and the role a higher output resistance plays (voltage division) when measuring THD at the output of a black-box (amplifier + output resistance) ?
