Feelas
- Joined
- Nov 20, 2020
- Messages
- 391
- Likes
- 320
I did not, but well - you need to because if you do establish a common reference, there will at least might be some semblance of neutral. Right now, if nobody knows what to target, neutral is impossible. Why wouldn't targetting the preference as a neutral reference make sense?You misunderstood the question.
You have explained why you want to equate need and preference. But you haven't explained why you need to. Just stick to using the term preference since there is no disagreement that's what HTR describes. There is no need to use the term neutral when there is obvious dissension with your attempt to do so.
Neutrality doesn't exist, common reference makes it possible. There's a good reason to consider going from wanting a reference to trying to lobby for it.
