Hi
Just pull the ribbon, you cannot live it connected
But how do I connect when programming is done?
There is no latch to connect/disconnect?
Hi
After programming you just push it again, it is easyBut how do I connect when programming is done?
Now I managed to reprogram the X16.
There was some problems with the software due to it wanted me to update.
But after trying a couple of times i got the correct answer from the software.
I veryfied kt by a DSD=file someone at the forum created with a testsignal.
I appreciate your help and support @k525!
Thank you!
YesGreat job Mio!!
Do you agree that it is a very satisfying operation??
Now you have a perfect X16!
my compliments!
regards
Yes
It feels good to have done this.
Now I don't have to imagine hearing crackling when playing DSD...
Also didn't thought I was able to do this due to lack of knowledge.
Now my set is to look for a preamp and H16 looks interesting...
Thanks for the firmware date info. In my case, I've been playing DSD for sometime now. No issues at all, my firmware date is 20201210. I'm not using the X16 volume control, output is set to 00.
Edit:
Played around with the volume control on the X16, -10 or -05 into my integrated amp. DSD on my X16 still plays fine without any issue, so I set it back to 00 as before. It's a very good dac, thank you Gustard.
I all
I am confused what to buy ,Gustard X16 or topping d70 s . dac only , source will be bludound 2i,
I See review that say this dac sound thin and without emotion
https://soundnews.net/sources/dacs/gustard-x16-dac-review/
please help
choosing
Thanks for your help.
So if mqa is not necessary ,d70s is the better dac ?
D70s is the only dac from us now that still has AK4118 in it. To use spdif input it's recommended to have AK4118.Thanks for your help.
Optical or Coax input from SACD player. The X16 will only recognise and play normal CD discs, does not see them if SACD.You mean an optical input from an SACD player? Or a music file with an .ISO extension? Or a DSD or DFF extension?
what is benefit of this "AK4118 "D70s is the only dac from us now that still has AK4118 in it. To use spdif input it's recommended to have AK4118.
It's acknowledged that cirrus logic receivers have some compatibility issues with certain streamers/cd players. I can't say for sure Node 2i is incompatible.what is benefit of this "AK4118 "
thanks shay
