Gustard X16 Balanced MQA DAC Review
After programming you just push it again, it is easy
Now I managed to reprogram the X16.
There was some problems with the software due to it wanted me to update.
But after trying a couple of times i got the correct answer from the software.
I veryfied kt by a DSD=file someone at the forum created with a testsignal.
I appreciate your help and support @k525!
Thank you!
Thank you!
Great job Mio!!
Do you agree that it is a very satisfying operation??
Now you have a perfect X16!
my compliments!
regards
Great job Mio!!
my compliments!
regards
Yes
It feels good to have done this.
Now I don't have to imagine hearing crackling when playing DSD...
Also didn't thought I was able to do this due to lack of knowledge.
Now my set is to look for a preamp and H16 looks interesting...
Yes
Great Mio
About preamp I am very satisfied of my Topping Pre 90, it works well with X16
regards
Thanks for the firmware date info. In my case, I've been playing DSD for sometime now. No issues at all, my firmware date is 20201210. I'm not using the X16 volume control, output is set to 00.
Edit:
Played around with the volume control on the X16, -10 or -05 into my integrated amp. DSD on my X16 still plays fine without any issue, so I set it back to 00 as before. It's a very good dac, thank you Gustard.
I have an audiophile DSD64 album that has horrible popping and crackling. Roon converts it to PCM and the X16 shows it as PCM. If I play it from Amazon music HD....it also pops and crackles. If I play it from JRiver - it shows up on the X16 as DSD and doesn't crack and pop.
None of my Flac or MQA files do this.
I haven't read all 148 pages here so apologies if I'm repeating a query already discussed. I love my X16 but it won't recognise an SACD input. I've seen reference to SACD in the manual but its all in Chinese - can anyone please explain?
You mean an optical input from an SACD player? Or a music file with an .ISO extension? Or a DSD or DFF extension?
I all
I am confused what to buy ,Gustard X16 or topping d70 s . dac only , source will be bludound 2i,
I See review that say this dac sound thin and without emotion
https://soundnews.net/sources/dacs/gustard-x16-dac-review/
please help
choosing
If you are looking to play MQA, then it has to be the Gustard X16 as only the Gustard X16 and Topping D90SE are capable to get MQA from Node 2i via Coax. If you don't care about MQA, then D70s is fine.
Thanks for your help.
So if mqa is not necessary ,d70s is the better dac ?
Check both threads here at ASR and get the most reliable out of the 2. Both are great performers DACs.
Optical or Coax input from SACD player. The X16 will only recognise and play normal CD discs, does not see them if SACD.
Because SACD have a copy protection. You will have to use analog out from the player.
what is benefit of this "AK4118 "
thanks shay
It's acknowledged that cirrus logic receivers have some compatibility issues with certain streamers/cd players. I can't say for sure Node 2i is incompatible.
You might try other devices if you want to. Or other devices that has AK4118. AK4118 is shown to have no issue with any of these devices.
