Grea job!I'm very happy to report that the update process is finally complete, and that DSD now plays back without any issue. The crackling sound at quiet or near-silent passages is gone. Hooray!
which kind of programmer did you use?
regards
Grea job!
regards
Anyone know any places that include a free two year warranty? I normally use Amazon or Apos but Apos told me to get a D90SE lol.
Amazon has no prime options so I’m at a loss where to buy one. I don’t want to buy SMSL or Topping had mixed results in the past with them.
Well, is $500 vs $900. Almost 2x more. Totally nonsense comparison.
Btw, they should updated the old CSR8675 already, with at least a QCC5141 (BT v5.2). Not fan of BT anyway, just saying.
It should also work. Make sure you have the correct driver for CP2102 and start from the second step in attached tutorial.
Fixed, see the post bellowHi unfortunately I was unable to update the firmware with a CP2102, the update program seem unable to check mcu it stay long time in (Checking target mcu..)
any suggestion?
regards
I don't know if I can help you. The driver of the USB programmer is in the compressed package, and the COM device can be found after installation
I still wait for a photo inside x16 from you. PleaseFixed, see the post bellow
Sorry,caocaolatre199x to have a photo of the mainboard it would have been necessary to remove several other screws to slide it out, but I was already quite overloaded given the problems I had, I preferred to close everything!I still wait for a photo inside x16 from you. Please
Oh okay, thank you!!Sorry,caocaolatre199x to have a photo of the mainboard it would have been necessary to remove several other screws to slide it out, but I was already quite overloaded given the problems I had, I preferred to close everything!
It’s very elegantHere you go. I was curious enough the first time that I opened it and snapped a photo. Sorry about the ribbon cables.
nice, thank you.Here you go. I was curious enough the first time that I opened it and snapped a photo. Sorry about the ribbon cables.
