Bluesound Node (
review) was questionable performer. I'm sure there are better streamers.
MiniDSP Flex (balanced with TRS) (
review) is a great DAC/pre-amp/DSP, etc. Highly recommended for stereo with the ability to hook up dual subs (end-game type of setup).
Amplifier is Topping PA5 (
review) is awesome (when it works!).
But it still has
major issues, so I wouldn't tell anyone to buy it until Topping acknowledges and fixes the design.
Fritz Carrera speakers. I don't know of this brand.
I personally don't buy speakers that we haven't seen full spinorama for. There are dozens of speakers that we have measurements and we can guarantee that the performance is great.
See my '
passive speaker' recommendation thread for speakers depending on your budget.
We don't know your budget.
Upgrade to Topping PA5 is Hypex Ncore or Purifi amps.
Here's a
spreadsheet (made by ASR member) of known amps, their performance and pricing.
If you get the MiniDSP flex (with balanced TRS) to connect your TRS balanced cables from your balanced amplifier, then you'll need to convert a TRS cable going from your Flex to an RCA (most likely) connection of your sub.
Keep in mind, that you'll lose 15dB of SINAD by doing this, as explained by MiniDSP.
For a subwoofer, you need to know your room size, since that dictates your required subwoofer. See my '
subwoofer comparison' thread to find a sub for your needs.
Peace!
