Of course you will. And the first thing you'll do is to make the input stage MOSFETs wide and long so you can get the 1/f noise down and get away from the short channel effects. I hope that once you start typing the channel length in microns in your CAD tool, you'll realize that you're wasting a metric s**ton of money on your 32 nm mask set.Also designing opamp using 32nm process etc. Designing audio is easy. I didn't have the scope for years until I finally realize that audio is just something in your heart. I'll be doing 32nm 1V opamp or 0.2nV/sqrthz 200MHz BW 100dB gain amplifier or something like that.
Have you ever designed an opamp at the IC level? I mean... In the industry. Not as part of some class project. I have. I designed the LMP2021. I've designed several opamps used as building blocks in other ICs as well, including the LMK04800 and LMX2581. But I guess I'm not a real engineer, so what do I know...
Tom
