Waterfall plots are often misleading, depending on the X, Y axis, dB scale and methodology. Sometimes they show things that seem to be inaudible or don't even appear in any other measurement and other times they merely reinforce what is already obvious from the other measurements(resonances and such).
I would say trying to compare waterfalls across different sources is a fool's errand, don't even bother.
I can't find this review, can you link it or provide a photo of the graph? Not going to spend a lot of time trying to find it.
But anyway, lets look at the KH150, a brand new monitor that everyone agrees is state of the art, vs the 8361A which is using a similar woofer design as the current 8351B.
What does any of this mean? The KH150 is a bit smoother because it doesn't have a woofer crossover. Mind the X-axis scale, they're not the same. I don't see many/any significant differences at all. The 8351 is better in some places, the KH150 in others.
At most we see variations of like 2-3ms. What are the decays in your actual room? Because even in a treated room, they're often 100ms+ below 200hz and 50ms from 200-500hz. So 10x or more of the decay time of the speaker itself. And if your room isn't treated, then it's much longer than that.
I have never seen any evidence that decay times of speakers correlate with audible decay times in rooms to any meaningful degree. *Sometimes* the waterfall reveals resonances but there's none of that in Genelec Ones.
