Focal Celestee Headphones
Musichead
Hi Everyone
I would like your ideas on getting custom cables for Focal Celestee headphones. The ones that came with them are too ridge and not long enough… any suggestions?… budget around $200 aud
Thanks in advance
Jimbob54
Not a direct answer but that dual 3.5mm earcup termination is also used for the bulk of hifiman phones too if it helps your search .
Your regions eBay /Amazon should have quite a lot or there is going direct to boutique retailers to have made up but that gets expensive if they aren't located in Oz for you.
