Saturn94
- Joined
- Feb 17, 2023
- Messages
- 115
- Likes
- 115
The cable that came with my Drop+DCA Aeon Closed X headphones is too short, so I’ve been using a cable extension. The connector on the cable extension is now failing. I’m thinking instead of buying another cable extension I would just by a longer replacement cable to eliminate the extension as an additional point of failure. I’m looking for something well made and easy on the budget (under $100).
I thought about trying these.
However, I noticed they are covered with some kind of woven sleeve and am concerned about it being noisy whenever I move and it rubs against anything. The cable that came with my headphones is smooth and doesn’t make any noise, but sadly it’s too short.
Since that cable is custom, and therefore not returnable, I was hoping someone here who has tried these cables can tell me if they are noisy or not, or if there is another brand I should consider.
Thanks.
Custom Dual Push-Pull Balanced Headphone Cable for DCA / Mr Speakers
Please include an email when checking out for all custom orders. If an email is not provided, and we have a question about your request, this may result in your order being canceled and refunded. This is a customizable version of our standard HC-12 headphone cable. You can choose from the...
hartaudiocables.com
Thanks.
