EQ for Headphones
Musichead
Hi Everyone,
Is there a EQ app for iPhone that anyone can recommend?
I have just received my Focal Celestee Headphones and would like to play around with levels etc
thanks in advance
solderdude
The Neitherlands
Search function is your friend.
Dunring
Florida
I use Poweramp which has the Autoeq database of profiles for thousands of headphones in it. Makes it really easy, but would recommend adding some power to compensate for the preamp reduction. A $9 apple USB to 3.5mm at the minimum, but the Tanchjim Space would really be ideal for those.
