flac file played by blu-ray to DAC: bit perfect?
skyfly
Is this a bi-perfect playback?
FLAC file played by a Blu-ray player
-> HDMI cable
-> TV
-> optical cable
-> hi-fi stereo DAC
Apesbrain
East Coast, USA
Not necessarily; the TV may resample digital audio. FLAC via BR player to DAC over optical should be "bit-perfect", though.
If TV does resample, it's typically to 16/48. What does your DAC report about the file?
S
skyfly
What is decoding your FLAC file?
I guess the Blu-ray player decodes the FLAC file. It can search playable audio/video files on the UBS stick inserted to the USB socket on the front panel.
The list of playable music file types on a disk or USB (from manual).
mp3, wma, wav, m4a(DRM Free), flac
S
skyfly
The DAC does not display sample rate or bit depth. It merely shows which input (optical, coaxial, USB) is selected.
