200hz seems a bit limited given that the crossover point is around 1.7khz, but it's a point well taken nonetheless.As for noise comparisons with a standalone amplifier... The noise bandwidth is only ~200Hz, not ~20,000Hz.
Correct.
Not to take sides here but everything else is mostly subjective. It is the interpretation of the results and the overall narrative that gets to be subjective. Most of it is very subtle but that is the nature of human frailty. I don't think it does anyone favors by pretending otherwise.
The only objective interpretation is when something is really broken engineering-wise and that is surfaced in the measurements. That is the greatest contribution of this site over everything else.
1. The Panther award is subjective.
2. What measurements to make of one equipment vs another when both do not have the same set of measurements is subjective.
3. The tone of the review is subjective (small irritants like the HDMI not working when connected can send the whole review into a negative narrative and interpretation)
4. How much leeway you give a manufacturer who co-operates with ASR than one who is aloof is subjective.
5. The recommendations based on a trade-off of mixed results is subjective.
6. How you normalize measurement of old and used equipment to compare with new equipment is subjective.
7. The evaluation of a piece of equipment relative to its price is subjective.
8. Choosing to selectively mention that a "measurement is not audible" or "that there is very little source content at that FR" but not doing so everywhere puts a subjective spin on the overall narrative.
The above is by no means faulting ASR but it will be taken as such because there is a false sense that the reviews here are purely objective. There is objective data one can choose to interpret any way they want and as objectively/subjectively as they want but one has to admit almost the entirety of the followup discussion is influenced more by the initial narrative tone set up than each one pouring over the data to objectively conclude.
Once can arguably claim that the reviews here are based on objective measures more than any other site but that is a different claim than saying that the reviews here are purely objective. It would be absurd to believe that people are not influenced more by that subjective tone and narrative than by looking at each measurement on their own with no subjective interpetations.
Sites like SBAF have their own narrative as well and behind all the hyperbole, the point really is the above.
It is two communities with their own identity circling wagons and their own form of hyperbole.
Of course. And a few actually do. Then you can add about 20 dB to the price though.Should this necessarily be the case, though? We could set a different bar for active speaker amplifiers if we want to, but you can cram a Purifi/Hypex module in there with some elbow grease.
Of course. But -70 dB H3 at 1 kHz, 5 W level (as seen in the T758 example) isn't what I'd call "safely inaudible". (If that's at 1 kHz, what's it doing at 10, or IMD wise? Or at higher power?) It's 2020, and <-80 dB THD at reasonable levels really isn't too much to ask for in any full-range electronics with any kind of half-decent component budget at all. State of the art has gone way past that. Of course nobody needs sub-ppm level distortion, but if you fail to clear the bar set in the 1980s despite having all the necessary means that's not really very good engineering, is it?I'm not averse to saying "this amplifier measures meaningfully better than that one", but I start to get pretty leery when we're calling products meant to be listened to bad because of nonlinearities we don't hear - I think a lot of less versed people get misimpressions about where their money is best spent, among other things.
So ... Chicago deep dish pizza?
They are not unrelated.The worst pandemic in the world right now isn't Covid-19, it's obviously Stupidity-101.
Nothing to see here, move along......I must have missed it, what did PS Audio say about ASR?
Assuming that we're in consensus that a 3rd harmonic at -70dB isn't going to be audible under any circumstances - which is how I read you - it would seem to me that the way to see how the amplifier would do at difference frequencies and levels would be testing those frequencies and levels, generally - depending on the amplifier's specifics, how it behaves under other circumstances may not be easily inferred from one test level, load, and frequency, and I'd love to see something more like powercube measurements if we wanted to peer more deeply into amp behavior.Of course. But -70 dB H3 at 1 kHz, 5 W level (as seen in the T758 example) isn't what I'd call "safely inaudible". (If that's at 1 kHz, what's it doing at 10, or IMD wise? Or at higher power?) It's 2020, and <-80 dB THD at reasonable levels really isn't too much to ask for in any full-range electronics with any kind of half-decent component budget at all. State of the art has gone way past that. Of course nobody needs sub-ppm level distortion, but if you fail to clear the bar set in the 1980s despite having all the necessary means that's not really very good engineering, is it?
What we absolutely need and what we should be getting for the price are two different things. For example, DACs have been so good for decades that, in general, you really have to try to make one that sounds bad. It's good to know that even a fairly inexpensive one is likely to be transparent in typical applications, but a higher-priced one with higher-spec parts better deliver higher measured performance as well. (There are a few applications that actually demand higher performance than you might first think, notably directly driving a power amp.)
Active speakers are a holistic product and tested and used as such. You can't start pulling out the amplifier section and testing it the same way as a power amplifier. For a start, many have significant EQ or DSP built in to the front end and will give meaningless results and/or they are tailored specifically to the impedance characteristics of the bass driver itself.
"A while back, a few members suggested that we do a review of Audio Science Review. I didn't think it was a good idea back then because I wanted to avoid drama. Now I think it's about time."
