This reply of mine does not make much sense, unless seen in context.Yes, it can. If the room/listening distance is not too large, bass is reproduced by a decent bass-system, and the driver/speaker has high output capacity - it needs to handle both high current and quite long excursion.
Of course, because the sound intensity and directivity is directly related to the size of the radiator.SPL is part of the equation, but not the whole story, I don’t think.
Here I mean sound intensity, it is a defined physical metric, I = p x v, where I is the sound intensity, p is pressure and v is the velocity vector. Intensity is the power of the sound.Intensity seems like it should depend on power applied and efficiency, a corollary of sound pressure level. To the extent efficiency differs with driver size, I can see where intensity would also differ.
To clarify not the radiator area but the volume of the radiator displacement.Of course, because the sound intensity and directivity is directly related to the size of the radiator.
SPL is created by the displacement volume of the driver.The topic comes up from time to time in discussions of speaker reviews. Rather than contribute to derailing of a review thread, thought I’d post here.
Can a 5-in mid/bass driver, properly implemented in a well designed system, eq’d and level matched, produce output that is audibly indistinguishable from the output of a system using, say, a 10” or 12” driver? Based on personal experience (a limited resource for sure), I would say no. The output of a larger driver will produce a superior sound quality in the mid and upper bass, and it will be easy to hear the difference compared to a smaller driver.
Old audiophiles are like cat ladies, only with subs.Yes, for bass you need serious displacement. If you are talking sub bass then displacement and cabinet size is king. Think like a huge JTR sub. Big driver and big cabinet. Near field is so easy to do it is really almost buying any decent set of speakers.
I should bring up a point of safety here. Do not ask me how I know this OK, young and dumb. Do NOT ever think that subwoofer bass can't hurt your ears. It will and can hurt your ears at high levels. Protect you hearing at all times and don't put your head inside commercial sound giant bass bins and crank it up. You will regret it later in life. So, with safety out of the way, the old adage is buy as much and as many subs as you can until you hit the "just plain crazy" level.
My own personal test back in the day was the old incandescent lights bulbs, if you are breaking the filaments with your subwoofer set up, you have great bass!!! Or, maybe a bit too much? Either way, I liked it.
I would think this post rest the case.SPL is created by the displacement volume of the driver.
Vmax = (Diameter / 2) ^2 x Pi x Xmax
For every halving of driver diameter you need to increase Xmax four times in order to generate the same SPL. You can imagine the physical consequences of such an increase. No amount of clever design can surmount such a large barrier. A small speaker is most of the time will perform worse than a large driver.
There is a difference. Same displacement from a large area creates a sound field with higher intensity compared to the same displacement with a smaller area.To clarify not the radiator area but the volume of the radiator displacement.
Exactly. Even if it was possible to make a driver with no excursion limit, it will soon move so far that the cone can no longer fit inside the cabinet. This will also lead to severe nonlinearity due to the compression of the air inside this cabinet.SPL is created by the displacement volume of the driver.
I am not sure I understand this. What is the definition of a high intensity sound field then just high SPL?There is a difference. Same displacement from a large area creates a sound field with higher intensity compared to the same displacement with a smaller area.
You talk about kr but not define it. Is it k x r (radius)? If so what is k?At very low frequencies, the difference is no longer significant, because of 2 things - the knee-point on the radiators acoustic impedance is much higher in frequency (around where r == 1 wavelength), and the speaker couples to the boundaries of the room.
Above the kr=1 point, the acoustic impedance is dominated by the real component, pressure and velocity are in-phase, creating higher sound intensity. Below the impedance becomes reactive, and pressure and velocity are 90 degrees out of phase -> less intensity for same pressure.
Question. It's this due to "turbulence"? I mean, non-linearities of the fluid dynamics?the air velocity simply becomes too high, which creates very high losses and distortion.
k=w/c0, where w=2*pi*f, c0=velocity of propagation of sound. The knee-point is more correctly referred to as critical frequency, when talking about acoustic transmitters;I am not sure I understand this. What is the definition of a high intensity sound field then just high SPL?
When we talk about low frequency (bass) we talk about frequencies around 40Hz where the wavelength is 8.5m. According to your description no driver on the market can couple to the room as even a 12" driver is 30 times smaller. Unless that k has a high value.
