Excellent link
Excellent link
No. The work is not theory, far from it. It's scientifically tested. The correlation between anechoic prediction and listener preference is IIRC 90%. Not being 100% is no indication at all of a poorly designed test or incorrect conclusions.
You may have read the book but I'm not sure you took in what was said.
The work is peer reviewed and presented in places such as the AES. Do you have any credible contrary testing/information/theories?
Would a contrary view be that people prefer a non flat anechoic response with wonky off axis and resonances? That's really the only place to go away from the Harman research. Seem unlikely to you? It does to me.
And yet...
I personally found a wide range of music that I played through the "badly designed" Devore speakers more compelling than on, for instance, Magico, Paradigm or Revel speakers I auditioned.
Just because work is peer reviewed and presented doesn’t mean it’s proven and unassailable. I have publications in science and engineering (including several as first author) in peer reviewed journals. Ive given talks at science conferences on my research. I’ve also reviewed or referee’d scientific articles for peer reviewed journals as well. It doesn’t mean as much as you are letting on.
It’s a theory because it tries to explain observations without a mechanistic understanding of what is gong on. There is no mathematical model and o molecular mechanism explaining why it is the way it is. For example, the test were performed in the US. How do we know the tests would result the same in Europe or Africa? How do we know those populations don’t have a certain genetic make up that would predispose them to favor a different set of speaker design principles.
Just because work is peer reviewed and presented doesn’t mean it’s proven and unassailable. I have publications in science and engineering (including several as first author) in peer reviewed journals. Ive given talks at science conferences on my research. I’ve also reviewed or referee’d scientific articles for peer reviewed journals as well. I’m also pretty sure that the standards for peer review for AES is lower than many other fields. It doesn’t mean as much as you are letting on.
Of course it's not unassailable. I never said it was. What I asked was if you had any contradictory evidence, tests or information.
Otherwise you are just saying "anything can happen" without reason.
So what is your objection to the conclusions!?
It’s a theory backed by the best data we have. If you can present similar or better data in similar peer reviewed publications that have different conclusions then by all means we are (pun intended) all ears. Your theory and mine and anyone else’s here would at best qualify as “expert opinion” (if we can even call ourselves that) which as you probably are aware has the lowest grade when writing medical and scientific guidelines.
Their work is the best within a weakly researched field. Best minds in the world arent clamoring to get into speaker design or research. There is no DoD and NIH grant money for this kind of work. Simply accepting their work as the gospel without independent verification is my definition of being dogmatic.
Dismissing it without reason due to personal views is equally dogmatic.
No. Those assertions are quite reasonable.
As a scientist I am sure you will agree that assessments made sighted are faulty. Bias will rule the conclusion.
No. In stereo the same rules apply. Toole states that without exception the speakers favoured mono were favoured stereo. You are conflating the ability to more easily hear faults in mono with being less important in stereo. That's not the case.
The theories do not lack predictive powers. They predict with very high confidence what will be preferred from the anechoic measurements.
Ok you don't like speakers that are neutral. That's, fine, but that's about you a sample of one. It's not about what makes a good speaker
The burden of proof lies with the one espousing a new theory. The theory can be supported by independently repeating the same tests in different labs. I can poke holes by offering alternative theories. If my theories are plausible enough t's up those espousing the theory to devise experiments that disprove my theories. If I'm being dogmatic, it's that I'm dogmatic about the scientific method.
No you have it backwards. Being less noticeable in a multichannel environment doesn't make the attributes less important or desirable, it just means it less noticeable.O'Toole himself writes in his latest book "[a]s active channels were added to the presentations, the ability to distinguish between sounds of different timbres appeared to deteriorate." He also gives a specific example where EQ coloring the sound was deemed bad in mono by a large margin but was almost unnoticed in stereo mode (was judged to be close to superior). This certainly suggests that certain technical attributes of a speaker are less important in stereo mode because those attributes cannot be as easily discerned in stereo modes. This is the case.
Like I said, I don't have a problem with O'Toole conclusions. I take issue more with how others use O'Toole conclusions to advance their assertions. But based on what you said above, I'm led to believe that O'Toole findings only have predictive merits in anechoic environments and thus have no merit in home stereo settings?
I don't deny I am a sample of one. You conveniently left out where I mention that the market doesn't flood to speakers with exemplary measurements.
Which they have demonstrated with scientific testing.
BTW do you also think that amps, dacs, cables, speaker wire and power cords have huge differences in sound quality?
Why? Some evidence please.I believe amps make a big difference. That is it.
No. Tooles research correlates with a very high level of confidence anechoic measurements with in room listener preference.
The market has no bearing on this. The variables involved in purchasing decisions are huge.
Not least of which the bias of sighted decision making.
f my theories are plausible enough it's up those espousing the theory to devise experiments that disprove my theories.
