Phase Tech PC 3.1 Speaker Measurements
Using a 1.5" mid with a 1" tweeter is honestly a bit weird. A 2" mid + .75" tweeter could achieve a lower woofer crossover point and better high frequency extension.
Back in the days there was endless amount of German 3-way speakers like these
Canton, Heco, maybe Saba, Braun and some other.
I only heard one Canton model and it was plain awful, nothing like hi-fi at all. I mean, even Mission 760i were on the next level.
Crossing over to a 1.5" "midrange" at 800Hz is certainly a choice.
The foam in the woofers I believe is intended to mitigate high order distortion products. It does technically work but is a bit pointless when the rest of the speaker is a distortion/resonance factory.
I believe the woofer cones are solid styrofoam. I remember examining promotional store samples, years ago.
These are the measurements of a used/vintage Phase Tech PC 3.1 center speaker. I believe it originally cost US $600. I was kindly sent to me by a member:
As you can see, the sample is a crusty one! :) I must say, I had not seen foam over woofers before. You can rotate the midrange/tweeter assembly as to use the speaker vertically.
Owner told me that this was one of the companies paying attention to directivity as being an important thing. Seeing how it has a mid-range, gives me hope that it delivers on that.
These write-up is rather brief because I am not sure if I have a working sample. I cannot find any measurements of this unit. There is some for the version 2 which looks better.
Our anechoic frequency response shows clear problem where the mid-range is supposed to be delivering:
From memory, the midrange is crossed from 700 Hz. That would in theory fill that hole but maybe they wanted this kind of V shaped response. Besides that, we have a few wide resonances. Directivity is not great causing early window and predicted in-room responses leaving something to be desired:
As noted, the mid-range should be solving the beaming issue with dual drivers but it clearly is not:
Vertically of course doesn't have that problem:
I was surprised and dismayed that I could clearly hear distortion at 94 dBSPL:
This is topped by very low impedance:
Finally, waterfall shows resonances as we would expect:
It should be obvious that this is either a broken speaker or broken by design. I can't be sure which is which. Could have discarded the measurements but after all the work that went into it (including confirming that the midrange was working), I thought I post it anyway.
I owned a pair of speakers in the late '70s that had foam over the woofers (and the front baffle) -- the Cizek Model Two: https://www.stereonet.com/forums/topic/288890-sold-fs-cizek-model-ii-immaculate-original/
Thought they sounded great at the time.
We have this unusual, flat distortion peak:
Notice how it hugs the line on the left. I don't think I have ever seen that before. So maybe the foam thing works in which case, one has to wonder why it is no longer used.
Thanks for the test Amir. :) Phase Tech PC 3.1, rubbish. In the bin with it. :oops:
This Phase Tech PC 3.1, how old is it? Thirty years? Things should have happened since then. Speaking of development and with that hopefully improvements see page 4,#89 when AOR (technical developer at KEF) was kind and took the time to compare some different KEF drivers. Interesting, I thought anyway:
Years ago I had a pair of their small bookshelves. The foam surrounds rotted and I pitched them.
I don't understand reviews like this. By the looks of it, this center channel speaker saw a lot of use. Was is abused? Who knows. But, if it was used daily, it likely needs considerable TLC. From the photos, the fabric dome mid and tweeter are quite faded and dull. They could have pits through the membrane as this is pretty common with fabric dome tweeters >20 years old. I wouldn't doubt the tweeters also need ferrofluid replaced (if they have it) which can be dried up by now. Regardless, these possible issues can ruin the response and significantly increase distortion. And who knows the ESR/capacitance of 30 year old electrolyic capacitors in the crossover network. Were they tested?
What would be an interesting exercise is to explore if there are such problems. Then see if the speaker be improved, with little cost or effort.
There is no ROI in spending that kind of energy to do that. As is, a single set of measurements and posting costs about US $2,000 in opportunity cost. I could buy the owner a new speaker than spending that money again on a speaker others are highly unlikely to have.
There is no sign of "abuse." The tweeter is also working fine. As is, measurements kind of correlate with what is performed on version 2:
The Klippel distortion data shows about 5% THD @ 86dB around 1500 Hz and 4.3% THD @ 96dB at the same frequency. I think something is amiss when the distortion reduces as the volume is significantly increased. Since the acoustic transition from the woofer to the mid/tweeter dome is clearly shown in the directivity pattern around 1300 Hz, this says this issue is likely related to the mid dome. Where there is one issue, there are likely more.
I found this, it is essentially the same but a newer version??
Purple trace is the 3.1
Amir I believe you are showing the 9.1 response at the top of the page..
I found that review and the 3.1 measurement is at the bottom of page I have included it.
The "Huge" off axis dip is what made me realize this is the center speakers actual response!
