Hi all,
I'm using the Asus Xonar Audio Centre equalizer to add a bit more low end to my music. With the lower frequencies increased, it sounds like the sound is just muffled with the highs decreased, rather than lows increased. So I have the low frequencies turned up as well as the highs a bit.
Problem is, when I'm playing music the sound level will flucuate when there are bass notes playing in the song to when there aren't any. So when the bass stops, the sound is louder.
I'm using an Asus Xonar Essence ST with line out to a Topping L30 amp.
Just found the equalizer issue is only there when listening through the Topping L30, and not when listening straight from the Xonar card build in headphone amp.
Anyone know what might be causing this or how to fix it?
Thank you.
Thank you.
