You should upgrade or use an
alternative browser.
I don't think Ethan is right about this one. Comb filtering certainly is a thing, and you can certainly measure it with a static...
By the way, Ethan has claimed in the past that as a studio engineer, his hearing is far more sensitive to comb filtering than most...
I'm with @Keith_W. The graph differences in Ethan's Figure 1 will not be audible with program material.
Regards,
Wayne A. Pflughaupt
IMO the main benefit of banana plugs is quick and easy pluging and unplugging the cable from the amp and speaker. If you don't need or...
Loading…
Loading…
