I thought you had math audio plug in for foobar?To @Jimbob54: I installed apo eq and peace, but the frequencies don't match. Furthermore, I am not able to detect a difference between a flat eq and a hd 650 one. Honestly, I didn't understand the test.
Another time, perhaps, I'll make another trial.
Thanks in any case,
Davide
Not in your opening post you didn't. Please don't assume we have read all your posts in every thread when you ask for help. https://www.audiosciencereview.com/forum/index.php?threads/eq-setting.40211/post-1417794To @Jimbob54: I have always said that I use Foobar2000 and Powerdvd22 ultra for the Blu-ray pure audio with mshuttle. For this reason, I need an eq which affects the system and not the single music software
Are you using shared or direct mode? If you use ASIO direct or similar, the EQ won't work.But I cannot detect any difference between a flat eq, or the absence of any eq, and the 650 hd eq.
EAPO and the rest don't work with ASIO or WASAPI exclusive.Yes. I am use native Asio drivers and Asio proxy to use Foobar2000 with Topping dx3 pro.
That's probably the problem then. If you are in exclusive mode, only the settings in the app used to playback have any impact, all external apps wil be ignored.Yes. I am use native Asio drivers and Asio proxy to use Foobar2000 with Topping dx3 pro.
