Yes, which is why
I created a separate thread on whether we should correct to Schroder only, or full range. We should discuss this there. But in brief, I have done both and I much prefer only correcting to Schroder. However, I am open to the idea that I have screwed up all my attempts at full range correction which would explain why I do not like it.
Ah, I didn't remember that it was you who started that other thread - thanks! Didn't mean to go off-topic here; it just seems like a natural extension of the discussion since you are asking what might have gone wrong or what you might do differently, and since the "target curve is set too high" idea turned out to be mistaken, the full-range correction issue seems to be the only (or most likely) remaining explanation.
I'm guessing enough folks have already weighed in on the sofa question to give a clear consensus, but for what it's worth, absolutely keep the sofa in the room, in its normal position, for the measurements. It's no different than a door, a window, a wall, or any other piece of furniture - it will be there during actual listening.
In fact, because I do the vast majority of my listening by myself, I've tried taking listening-position measurements both with the mic on a stand at my listening seat, and with me actually in the listening seat, leaning back slightly and holding the mic where my ears would be. The resulting measurements are very similar, but they're not identical - my body no doubt adds some small amount of absorption (and maybe a little diffraction?). I doubt it makes much if any of an audible difference though - for all I know, the differences between the mic-stand measurements and the me-holding-the-mic measurements are within the margin of run to run variations or within the margin of differences created if the mic is 1/4" higher or lower run to run etc.
EDIT: Just saw your posts above about Acourate recommending putting a covering on the sofa, and
@sejarzo using that very clever dummy! My personal opinion is to keep it simple - why simulate the effect of me sitting there when I can just sit there during the measurement?
