Not quite true. I can still buy them in AustraliaAll 2500 pairs are sold apparently
A, what nummers?Not quite true. I can still buy them in Australia
I haven't been told...however, I have twice demo'd no 339A, what nummers?
So, I ended up with 232/2500 and there is still 231 unsold, plus the demo pair mentioned above.A, what nummers?
Try Vinylsound.ca They are located in the Toronto, Ontario region. Recent search shows they have some. Good luck!So, I ended up with 232/2500 and there is still 231 unsold, plus the demo pair mentioned above.
Does anyone know of any still for sale anywhere else in the world?
Try dedicatedaudio.com based in Scottsdale, Az they carry new and 6mo old returned units for under 6k !So, I ended up with 232/2500 and there is still 231 unsold, plus the demo pair mentioned above.
wow ! thats pure class A. What is your opinion of Class A vs others on pairing with Dhs? I believe the Devialet are primarily class Ds.
Also, did you look into
- pairing with Schiit audio products ? they have an Aegir which is class A {not comparable to your L anyday}
- pairing with the Purifi's 1ET400A/eigentakt technology based amps ? eg NAD c298
... I am trying to incrementally work out the best combination with my Dhs units
just curious, with the devialet did you have the option of connecting with & without the SAM tuning ? wondering what the difference was ?It's only class A for the first 60 watts (4 ohms); it has more net power than that, but it's no longer Class A.
In my room, it's still plenty of power and I never turn it up past 12 o'clock.
The biggest difference vs the Devialet Expert is the lack of SAM tuning, lack of built-in ADC/DAC, and the phono stage.
I am surprised that so few of you seem to run the HS with a sub.
Out of curiosity, have you experimented with "speaker placement" with Dhs ? One differentiator I found when evaluating wide range of speakers was actually the quality & quantity of bass that the Dhs puts out. Which suggests to me that perhaps "finer tuning" of the speakers could be helpful ?Good day everyone, #458 here
I have been following this thread for a few months now and you guys were partially responsible for me buying the Heritage Special. But really, I only needed a small nudge to fulfill a 35 year old dream of mine, haha. Also, I tried to find any negative reviews about the HS, but could not. So, here I am and you see me completely happy
I am far from being an audiophile, I just like my music to sound good. No question, the HS are overpriced but so are many other beautiful things. Currently, I am running them with a tiny hybrid amp from a Polish company called Taga - great warm sound and unbelievable value for money.
That said, I am coming from monster floor standing speakers which had a bass going down to 25 Hz (sounding even lower). Now, I do love sound of the HS but I can't help to want for a bit more substance in the lower frequency regions.
I have no experience with subs and so spent hours to read up on the subject. After (of course) stumbling over the usual suspects like REL and SVS and reading about marketing hype and a lot of "hot air", I resorted back to Dynaudio and found the Sub 6 which they market as the perfect match for their high-end shelves. Also, with matching presets available - sounds amazing. If only the price tag wasn't at 2.500 Eur here in Germany.
I am surprised that so few of you seem to run the HS with a sub. Actually, the only one I saw is @matro5 with a Sub 6. He seems to be happy with it. No one else with a sub?
Now I figured that the Sub 18s from the Pro Line is exactly the same as the Sub 6. Only difference is the finish, no cover and different presets. But it sells for almost half the price at 1.300 Eur. This seems to be great alternative since I don't plan to put the sub as an eye catcher in the middle of the room
Does anyone have experience with this model? Obviously, it should sound the same, I am just a bit worried about the setup (newbee)
Thanks again for pushing me over the edge - the HS will stay with me for the next decade, for sure.
Cheers, Stefan
Thanks @watchnerd,I use the HS with 2 subs.
I'm using dual Martin Logan Dynamo 1100X
MartinLogan | Dynamo 1100X
www.martinlogan.com
I am using the HTC-800 hybrid integrated amp. It has a tube pre-amp and a standard power amp with 2 x 75 W. I would never have found or tried them, but a friend is keeping them in stock suggested I should try it. It is very minimalistic concerning features but sound perfectly fine with the HS. That said, I will try the HTA 1000 one of the next weekends, just to see if a bit more power makes a difference on lower volumes.Out of curiosity, have you experimented with "speaker placement" with Dhs ? One differentiator I found when evaluating wide range of speakers was actually the quality & quantity of bass that the Dhs puts out. Which suggests to me that perhaps "finer tuning" of the speakers could be helpful ?
If I may inquire, which Taga Amp are you using the Dhs with ? and what made you choose that Amp ?
Thanks @watchnerd,
The specs look amazing and the finish for sure better suited for a living room than the 18s. You are using two because your room is so big or just because you can?
Cheers, Stefan
For German standards that's fairly big And yes, I have read and heard that two subs are better than one but I guess I will try one for starters. Also a question of budget and the local government (my wife).Well, big is relative between America and the rest of the world. My room is 35 square meters, the ceiling slopes from 3 meters to 3.7 meters, so a little high. But in terms of American living rooms, I would call that medium sized, not big.
But also, 2 subs are just generally superior when it comes to reducing bass resonance nodes in a room.
