I was going to recommend you disconnect and reconnect every plugged connection on both boards when you were in there, specially the ribbons. The micro level signals can be easily effected by a tiny connection irregularity. But your on a different path now. so just sayin,I am in the UK. Currently waiting for a response from what I assume is the NL based D&D office.
This morning with everything "cold", the speaker booted up twice without issue. Makes me think that taking the electronics out and putting them back has knocked some connection or loose solder joint back into position. I will keep testing every day.
Wish you the best of luck!
Sal1950
Only fair you name that frig manufacturer.I'm surprised that ASR users find this failure rate to be unusual. Other types of products often have similar or higher failure rates.
I've had early failures in laptops (a Dell and a Macbook Pro), smartphones (Google Pixel 2 and Pixel 7), and, most recently, a high-dollar refrigerator. The $13K refrigerator failed in 18 months with no possibility of repair and no replacement models in stock, and I practically had to sue the manufacturer to do anything about it. The regional head of repairs for this manufacturer told me, in a candid moment, that the failure rate for this model of refrigerator is 100% within two years.
In this light, a failure rate of 2.8% (which may amount to only one amplifier module failing in each speaker) strikes me as low. I did experience the cracked cabinets issue, and it was resolved with the mid-2018 redesign of the 8Cs.
Quite true but like the stock market or any other investment, we each have to individually weigh the risk against our ability to absorb loss.you can never become "old" without at some point being "new"
That thinking would have no suppliers eventually
Personally I would only invest in a more grounded company, but that's just me.
In any case it's issues like this that will keep me on the passive path for my duration.
If one of my 30yo Adcom amps should let the smoke out, I have a spare on the shelf just in case.
Same for everything in my system.
Worst case, I'm down an hour or so.
YMMV
This is the D&D thread and we know nothing about Geithain, I never even heard of them.I'm not sure how D&D gets targeted after we learn how, for example, Geithain treats its customers.
That said @nastypoker came here looking for help and along the way we learned of other failures.
I don't know if the % is high or low, but the discussion of the issue has been quite fair and I don't see
anyone kicking D&D unfairly. Schitt happens.
Exactly!I don't think this issue is "picking on" D&D. The combination of high power amps and high power computing power in expensive audio products has many examples of short lifespans and unavailability of parts (usually IC's) making them unrepairable. I bought a high end AVR that failed and could not be repaired due to lack of parts after just 5 years. The issue with high end proprietary electronics in active speakers is even more risky for the consumer as most of the cost of these products is mechanical but the whole system could be rendered useless for the want of one IC. Things happen even to good companies in this industry. I don't know the answer but the issue is a real concern for consumers.
