I just ordered mine from https://hifi-express.com/ and saved $5 with a coupon code. Free S/H and no tax. Wish me luck, lol.
Just the normal price in Europe (no discount), i wonder if shipping, delivery is the same as amazon.de (where i should get it from, when in stock i wonder why it takes so long to get one from europe) or uk
View attachment 145839View attachment 145838
As said before. I confirm this point specially for this infineon chip. You need a long break in to get the best of this amp. You will notice after a long break in : a best soundstage and also a great improvement related to the gain. ( I had to ajust it @-10db)
This amp is a real bargain. I could compare it to my Purifi / Ncore nc502 and Poppulse T180MD. It is neck to neck to these amps
Does anybody knows if the 15 V DC output of the Sabaj A20a is 2.1G or 2.5G ?
Thank you !I think you can safely assume it's 2.5mm based on my experiences. All the Class D amps I own with a barrel connector jack use that size. Even if the size is 2.1mm an adapter isn't hard to find and they're cheap. I've gotten some from the 'zon that work just fine. Good luck.
Is the size of the plug, outer diameter 5.5, inner diameter 2.5 (mm)Thank you !
The A20a's DC15V output jack is 5.5mm/2.1mm. Same as A20d DC jack.Does anybody knows if the 15 V DC output of the Sabaj A20a is 2.1G or 2.5G ?
Has anybody gotten the new version if so how long time dit it take from you orded one til it arrived?
More than 14 days ?
reported to Sabaj that I found a problem shortly after purchasing the A20a, and at the same time returned the item to the official shop. Some time later, Sabaj promised to send me an improved version of the A20a. It took a while, but Sabaj sent me an improved version of the A20a from China as promised. This means that the improved A20a has already begun to hit the market.When did you order the amp Toku ?
Could you please report on how hard it was to change the PSU once you've done it. I'd really like to know if you would have to screw both ends of the amp open in order to get access.That's amazing news Toku! I'm still waiting for a power supply to be sent to me to swap in, but I'm all the more excited now.
I also use A20a, Topping D10s and D10 Balanced in combination. You can perform a sound quality comparison test by connecting D10B to the XLR input and D10s to the RCA input and switching the input.My Topping D10 Balanced DAC came in and it pairs absolutely wonderfully with my Sabaj A20a + Philharmonic AAPM speakers! The noise floor is absolutely silent up to max volume on the amp, where my 2nd gen Scarlett Solo (unbalanced) was starting to pick up hiss around -24 (to be fair that is way louder than I ever turned it up to!). I've only listened to a bit of music so far and the D10B seems less smoothed over compared to the Scarlett, and imaging/instrument panning seems a bit cleaner. All things I can chalk up to the raw stats increase of the new DAC. It's just as neutral as the Scarlett, just cleaner overall. Highly recommended!
Side note: the D10 Balanced body width almost perfectly sits on the A20a, except the face plate is slightly wider! Not a problem for me but I know some people take their stacks very seriously
I'm asking Sabaj if he's planning on doing something for a sold product and I'm waiting for an answer.Could you please report on how hard it was to change the PSU once you've done it. I'd really like to know if you would have to screw both ends of the amp open in order to get access.
