Since the display of my SMSL AS300 broke (went black) and I need to send it in, I am considering the A20a as an alternative. I have no trust in the (O)LED displays SMSL uses for their amps anymore, since mine broke after only 4 month of daily use. I'd rather have a simple one that lasts over a beautiful one that breaks. Power-wise the AS300 is plenty for my Dektop usage tho.
My plan was to use a 108W Mean Well medical PSU to power the AS300. This would be ~50 bucks + another ~20 bucks for the case.
Unfortunately the A20a can't be connected to an external PSU unless you screw it open and connect the plug from the PCB to an external one. The qualities of the internal PSU (Morsun) seem to be in the okayish zone, but none the less inferior to a medical Meanwell.
Since its about rouhgly the same costs, what would you prefer?
a) AS300 +Medical
MeanWell 108W PSU
b) A20A +
Morsun internal 350W PSU
MeanWell medical:
Earth leakage current <
300uA A/264VAC , Touch leakage current <
100uA/264VAC
Line Regulation Rated load --
±0.2 -- Load Regulation 0% - 100% load --
±0.5
Output Ripple & Noise =
24V : 150mV /
48V : 240mV
Morsun:
Leakage Current 240VAC <
0.1mA; Single fault <
0.5mA
±0.5 -- Load Regulation 0% - 100% load --
±1
24V : 150mV /
48V : 250mV
MeanWell has much better Line&Load-Regulation, in fact
twice as good. From using a 108W power with 24V I would benefit from a much lower rippe&noise too compared to a 300W+ high power PSU.
What's better to have? More power or less, but cleaner power?
