So it sounds like that whole house surge protector works, if they were blown, just that you were in between and you can't find that that can withstand the level of surge you get.I was between surge units in the panel. (Hangs his head in shame.) I've replaced them in the panel a couple of times, now. They can take a hit pretty well but they will give up their lives in a big surge and they need to be checked routinely.
My panels (two 150-amp panels next to each other) were made by GE back in the day and I use the SurgePro THQLSurge in each one of them. It clamps at 500V L-N and 900V L-L and can resist surges up to 10 kA. So, not the greatest but the best I can get for these panels. I had tried units made by ham radio guys Industrial Communications Equipment that were rated at 50 kA, but those released their magic smoke within weeks of installation. They were wired into 60-amp breakers as specified by the manufacturer. I took those breakers out and the SurgePros went in their place. But one of them was blown when that extra storm passed through. I keep them in stock, but I don't take off the panel cover when I'm in a hurry and just hadn't gotten to it.
I have Homeline (SquareD) panels in my shop, and I use the HOM surge protectors in those panels--I doubt it's any better than the stuff above. But the shop has a Ufer ground that is just plain better than the copper ground rod my house uses. Those are still showing protection after a couple of years.
In both cases, these don't mount next to the panel. They mount in the panel, in the place of a two-pole breaker, with a pigtail that takes the shortest path to the neutral bus.
I've been tempted to install Edco 1210's, like we used in traffic cabinets in stormy areas like Texas and Florida. Those have a current rating of 20 kA, but the clamping voltage is only 350 V, so less stuff gets fried on the way to protection. But I doubt the installation in a residential panel would be suitable--the wires need to be really short. And it wouldn't meet code.
We have clay on top of granite here, so soil grounds are always a little shaky and that's true for pole bonding used by the power company, too. That's why I built the shop with a Ufer ground.
Rick "grounding on limestone was even worse when I lived in Austin" Denney
I grew up in Texas, which gets a LOT of lightning. Only Florida gets more. Here in Virginia, we don't get nearly as much, but it's not rare. Here we also have clay soil over old granite that is quite close to the surface. That means we don't get good soil conductivity with stuff we can install near ground level. Good earth grounding is the key to lightning resilience. When lightning causes a dropout in the power, the power drops momentarily and then comes back on, and that's when you a massive inrush current for all those users whose power is coming on at the same time, but maybe not both lines (or, upstream from the transformers, for all three phases) at once. And if lightning hits a power facility some distance away, what it hits will be vaporized but there will still be quite a surge that will radiate out.So it sounds like that whole house surge protector works, if they were blown, just that you were in between and you can't find that that can withstand the level of surge you get.
Curious where you live to get that level of lighting activities. I am fortunate where I live we don't get that many lighting, even when it rains, it's a rarity we get much lighting.
Well, best of luck to your electronics and appliances in your home. I guess the best thing you can do is keep at least 2 spare whole house surge protectors around and when it goes, replace it immediately.I grew up in Texas, which gets a LOT of lightning. Only Florida gets more. Here in Virginia, we don't get nearly as much, but it's not rare. Here we also have clay soil over old granite that is quite close to the surface. That means we don't get good soil conductivity with stuff we can install near ground level. Good earth grounding is the key to lightning resilience. When lightning causes a dropout in the power, the power drops momentarily and then comes back on, and that's when you a massive inrush current for all those users whose power is coming on at the same time, but maybe not both lines (or, upstream from the transformers, for all three phases) at once. And if lightning hits a power facility some distance away, what it hits will be vaporized but there will still be quite a surge that will radiate out.
We've had more outages here than when I lived in hurricane country in Texas. Trees are the usual culprit here.
Rick "and we get snow here, which never happened in Houston" Denney
Do you have any data on that?You could Lose your Job if you inadvertently turned Any equipment Off at the ABC/BBC, EMI or Air studios just to name a few, unless the equipment had failed and needed to go to the service department
There are arguments for both but InRush current when powering up is and can still be an issue, especially with less than ideally designed PSU's
A 'Filament' light globe that is Never turned off will vastly outlast one that is regularly turned off and on.
https://en.wikipedia.org/wiki/Cente... the,the Livermore-Pleasanton Fire Department.Do you have any data on that?
Because there are dozens of electronic items in a modern house that have power switches, often on the back where you can't reach them, and very commonly with long boot times and standby circuits. Turning them off and on at every need takes a long freaking time. That's why not.Some personally notes here within the thread, but answering the question:
Anything I don't need or use is switched off, if light, heating, hifi or other stuff.
Why not?
But I think you guys that go around your houses turning off dozens of electronic devices every night before going to sleep are a little nuts.
I just yell at Alexa and she does it for me. (But only for stuff like my Sub that doesn't have a standby and consumes a hefty combined 60W when not being used)But I think you guys that go around your houses turning off dozens of electronic devices every night before going to sleep are a little nuts.
I trust the community to let me know if Amazon are recording stuff they don't say they are.Ha! Alexa is where I become Amish. Too much clandestine listening for my comfort level.
Rick “who experimented with X10 controls once and thought they were closer to starting fires than leaving stuff on” Denney
I don't use Alexa, Google, Siri nor Cortana, because, they just aren't smart enough, they probably have another 10 years before I can use them without getting frustrated.I trust the community to let me know if Amazon are recording stuff they don't say they are.
And all the recordings are accessible and deletable. And very very (very!) boring.
Turn on my lights
Turn off my lights
Switch this on
Switch that on
Whats the weather
Set a timer
Add cornflakes to the shopping list
coffee on
Etc.
You can even set the retention time to 3 months, or set it not to keep recordings at all. You can delete them at any time by voice instruction or in settings.
Why in holy hell would anyone turn their heating system off?
