Yes!Just so we’re on the same page. In order to do the calibration correct with the correct routing, I should:
1) Delete the data from all of my presets.
2) Click on profile 1 on the left
3) Have routing set to input 1 Dirac 1 and input 2 Dirac 2.
4) Launch Dirac from the control panel.
5) Run calibration for stereo
6) Set target curve and export results to slot 1
I plan to make two calibrations, another attempt at a full range cal, and a separate stereo cal only correcting 0-350 or 0-500hz.
In fact you can do only one calibration.
Make sure slot 1 and 2 have correct routing.
Start dirac calibration.
Save full range filters on slot 1.
Save 0-500 filters on slot 2.
That is all.
2 calibrations are only needed if you change any parameter such the mic angle or position.
Otherwise, only 1 is needed.
You can then save your dirac project and with snapshots for each target curve or range that you can reapply later on any slots.
