I must have missed the mixing part earlier.
I assume you're using a NLE, does what your using not support an external control/console/interface?
for example like any of these
The few people I know that do professional audio work all use one, mainly because they want old school linear faders.
Don`t worry my friend. Nobody can not miss something on the way. Its a huge river of information. All good.
No i don`t use NLE. I tried a few over the years and always ended up not using them. I gave them 4-5 chances and it organically never survived.
"because they want old school linear faders.“ I work in the movies and i know sound recordists-mixers who use Linear and others Rotary mixers cause it takes less space.
It depends on the projects and where you work. If you are in a helicopter faders are harder to use. If you are in tight spaces also.
So there is no one solution for every case in my experience at least from what i see collegues do.
I don`t mind mixing completely with the laptop especially since i travel a lot and learned to work like this.
if i go to a studio that has one i might connect but it is very rare that i need anything external in this aspect. Much less that can go wrong like this
at least for my workflow.
However when i am at home i use the Flex for everything. It is the last link before the speaker system. If it was a „Normal Stereo system“ it would basically be the Pre Amp so in short , the Volume control.
So this is all i am missing. Everytrhing else is perfect with the Flex. It has pristine sound quality
I use the Motu Mk5 as the Primary Processor for the Audio processing, Mixing, Making music, Mastering etc.
When i am at home i then go via Toslink into the Flex and use the Flex volume logically which is driving the monitors and sub.
I wanted to try out DSP for the speakers. And it is awesome.
However before i was going Analog Balanced from Mk5 to an Spl 2Control Volume controller and the ease of use whenever i need to adjust Volume multiple times
comparing the Divine volume knob on the Spl to the wobbly sh… Encoder of the Flex with its 19 rotations …. Well lets say its day and night.
i however totally get that the majority of people finds what i say weird because they simply can`t imagine how bad it is if you have to adjust multiple times a day
to have such a laggy translation if that makes sense
