Digital sound, on the other hand, is made up of a series of discrete steps in its audio signal that change quickly enough that they give the illusion of a continuous signal when fed to a speaker. This is very similar to the way a video is made from a series of still images that are cycled through fast enough to give the illusion of smooth motion (hence the original phrase “motion pictures”).
It starts out with the biggest nonsense of all. Aside from some filterless NOS DACs playing 44.1kHz files can you show the steps to exist in reality ?
You could say that since a digital discrete signal is merely an approximation of the actual sound
No.. it is a VERY, VERY close approximation to the signal that was coming from the master but in almost all cases that master was digital but in a higher bitrate and bit depth.
That approximation is MUCH closer to that original recording than any direct cut vinyl master can ever dream of.
An analog signal is carved directly into the grooves in the record
No, it is carved in a master disc which is used to make a press mold which again is used to press grooves into a blob of vinyl and comes out as a disc with a groove on it (usually one on each side)
Do you really think that vinyl is limited only by the size of vinyl molecules ?
Is the frequency range of vinyl really limited by molecule size ?
Not by physical limits from the
lathe, the 'protection' in the cutting mechanism to avoid needles jumping out of grooves, the limitation of the used master, the limitation of the pre-amp ?
digital audio should be able to meet or exceed the performance of analog sound in both technical quality and sound preference.
News flash digital audio far exceeds vinyl and is always 'less' than the original recording (which in most cases is digital recorded and manipulated)
The fact that the changes made to the original recording by the mastering process, the vinyl cutting head of the lathe, the degradation right up to the pressings, the used cartridge (with all its various aspects), the adjustment and arm, the speed variances, the used RIAA pre-amp and still an enjoyable sound is coming from this (despite and thanks to the alterations) can be quite enjoyable to human ears says a lot about how forgiving the brain is dealing with the distorted original signal.
Yes, vinyl can sound more pleasant that doesn't mean it is more accurate or truthful.
