- Thread Starter
- #21
I didn't told you anything about not needing sub's with any of those. Sub will be beneficial with all of them. I don't like idea feeding something which input amplifier stage is supposed to be 4V with 1V from desktop computer audio card output, even if it's a proper unbalanced output of 2 V I am still against it aside of adapter cables.
I don't know it depends of available space on the desk then if you can place something like Kali LP 6 V2's on it. And actually again rises question whether would you put subwoofer. As long as you intend to use desktop PC to feed them (which might or might not be a good idea depending if it cause problems or not and if you are satisfied with quality it produces) with multichannel sound card adding a sub properly is not a problem along with getting all the necessary sound processing for free (EQ APO). Again assuming it's a Windows based desktop PC.
Only reason for recommending LP 6 V2's is their sound quality and that they will work good in near field. As no one mentioned already you should also look for Kali MM 6 which are the same as LP-6 V2 with addition of DAC and optical inputs. MM 6's where sold out last time I checked.
Edit:
They definitely can pass without sub with bass extension down to about 35 Hz with front firing port's and in near feald he will feel them. Luckily that's a deep work table.Measurements for speaker Kali LP-6v2
www.spinorama.org
Ah ok. We can go with the Kali LP 6 V2. No problem to put them on the desk on each side of the screen, there is enought space. But I am lost after your answer for what we need to connect to the computer then. Yes it is a PC with windows 10 and a multichannel sound motherboard.
