What about the prepros tested? Is there any chance that their measurements might have been affected?
Clearly not, because Amir said:
..............Our overall performance is the same with HDMI relative to Coax Input...........................
That's my understanding.
The Arcam AV40 maybe. I did not test Monoprice HTP-1 with HDMI so that is good. Same with Emotiva RMC-1.
Since i have the JBL SDP-55 which is the sister product to AV40, I will get to test it again and make sure.
Here is the 4700:
As you see, you can push it to 3.6 volts but after that, it severely clips the output from pre-out.
Does this mean the issue with arcam."large" mode is also similar fault with testing?
Also I have been using only 2.1 on my avr for a while, different brand but many people just use two speakers, as a avr offers hmdi and bass management, DD/dts decoding, something stereo amps lack
From Amir's X3500H test:Don't forget even the AVR-X3500H is very good too for an AVR/prepro if you keep use amps with 28 dB gain or more up to 200 WPC.
Maybe you could test the RCA pre outs with ECO mode enabled in those models (like 6014, if I'm not wrong) which don't allow internal amplifier to be fully disabled.
There could be a relationship between internal power amplifier heat/energy and the not-so-good output at 2v. Maybe ECO mode could help.
I also agree 2ch audio over HDMI should get scrutiny and perform well. Music listening via streaming services have become the most popular way to listen to music and people who want the convenience of an all-in-one solution will use these with streaming media devices to stream music from their app of choice primarily via HDMI
"Overall, you have a lousy DAC but a good amplifier with Room EQ at attractive price in Denon AVR-X3500H. "
Still curious about performance over that HDMI 2.1 port . . . .Last call for measurements before I pack this unit.
These are Amir’s comments in the review. However, I requested a lower output level and he tested 1v and got this. Note he says .5 better SINAD at 1.2. Like the X3600, I believe it remains good until 1.4v. This puts us at a SINAD of 96 as long as you don’t exceed 1.4v. @amirm I wish this 1-1.4v performance would be added in the actual review and the 1V test was in the actual review as it is important. The summary of “lousy dac” is of course correct at 2V but this is an excellent unit kept under 1.4v. It is a shame the most important test is not in the main review. In the main SINAD chart at first glance it would appear this is a bad unit. However, the most common use is not using external amps which some could require 2V. However if just internal amps are used and volume is kept at 79.5 or .5 on the master volume (basically reference level) you get a SINAD of 96. The something goes for the X3600 and probably the X3700. As long as you use it within the under 1.4v parameters, you get excellent AVR performance. For those wanting to squeeze max performance out of a unit, using amp disconnect or preamp mode will get you that extra bit of performance. But don’t loose site of the excellent performance if you use the internal amps of around 96 if you keep it under reference level. For me that would mean it would be a waste of pretty good amps to go full preamp mode. Just get an external amp that requires less than 1.5 or so to fully drive them. Fortunately many of the most popular HT amps do this... Monolith, Outlaw, Emotiva.From Amir's X3500H test:
If you have enabled at least the number of channels your source generates, then you are good. Going down in channel count is what causes the problem.
Why would you guys need an AVR to use it solely as a preamplifier? Wouldn't it be more practical to invest the same money in standalone multichannel DAC/preamplifier?
Of all the standalone multichannel units Amir measured, at the <$4000 price point, none offers equal or better SINAD, IMD, linearity, 32 tones test, FR performance than the two mid range Denon AVRs, that's one main reason.
