@Veganfloyd, one Audyssey tip I can offer: your fronts are showing that characteristic 1.8kHz dip. Since you have the app, turn off Midrange Compensation (MRC).
Yes, it's SINAD related but I rather have 2.0V (Pre-out only) going to an external amplifier vs 1.4V (Spkr + Pre-out)!
Denon AVR-X3300W Preamplifier Measurements
One thing I really love about Denon receivers is they NEVER skimp on their preamp out circuits. Like past models, the AVR-X3300W had an ample amount of drive. I measured a whopping 4.5Vrms unclipped output, which is more than double the voltage needed to make virtually any amplifier reach full rated power. Yamaha please pay attention and step your game up particularly with your AV receivers in this price range that clip above 1.6Vrms. A preamp output of less than 2Vrms is unacceptable in my book.
Agreed on all points. A simple toggle gets you “free additional performance” so why not?That's the misleading part though if you don't mind, because someone could interpret that as limited to 1.4 V when choosing speaker+preout, that is clearly false. Either way you will still get the same, or almost the same output voltage limit, right up to at least 3.5 V, if not the maximum limited by the volume control IC and opamps in the pre out signal path. At closer to the limit, such as 4 V, yes SINAD will likely drop to lower than 70 dB, but clipping is generally considered as SINAD reaching about 40 dB, that is 1%.
I used the following as an example a few time, but that's long time ago so I thought I should post it for new comers to see:
The X3300W, is 3 to 4 generations older than the current X3800H, it absolutely has no preamp mode, that is only speaker+preouts, volume control, opamp, dac ICs and circuitry were all very similar to the X3400H through X3800H.
Denon AVR-X3300W 7.2 Atmos/DTS:X A/V Receiver Review
The Denon AVR-X3300W 7.2CH Atmos/DTS:X networking AV receiver features the latest in HD audio and video processing, music streaming and offers future expandability with solid preamp outputs.www.audioholics.com
One can just read Gene's comments, if not the whole review:
Absolutely, for example, I have taken enough measurements to know that in any of my rooms, even 1 V will be more than enough for my power amps based on my listening habit, amp gain and speaker sensitivities, but given the choice I would definitely target devices that can do up to 4 V/8 V RCA/XLR at SINAD no less than 70 dB.Agreed on all points. A simple toggle gets you “free additional performance” so why not?
www.audiosciencereview.com
| Gain: | 25.5 dB | |
| Pre out Vrms | Power amp Vout | Power amp output W |
| 1.4 | 26.37 | 173.86 |
| 1.6 | 30.14 | 227.08 |
| 1.8 | 33.91 | 287.40 |
| 2 | 37.67 | 354.81 |
| 2.2 | 41.44 | 429.32 |
| 2.4 | 45.21 | 510.93 |
| 2.6 | 48.97 | 599.63 |
| 2.8 | 52.74 | 695.43 |
| 3 | 56.51 | 798.33 |
| 3.2 | 60.28 | 908.32 |
Don't get offended warning (as I may be stating the obvious things you already know...): In order to understand why, you should first make sure you are comparing apples to apples and it is easier to do if you just use 2 channel in direct mode to eliminate the effects of DSP, and go from there. Then you need to compare without knowing which one you are listening to, this part is difficult to do for the obvious reasons, but if you know which one you are listening to then it doesn't matter what you think you are hearing, as very few people, if anyone, are not influenced by "knowing which one.....".
Did you compare in direct/pure direct mode with no DSP/Audyssey? As above if done sighted, it wouldn't count but if the differences were really "large", and was done in pure direct mode under the exact conditions (speakers, contents listened to, placements etc.), then I would say it is worth measure the actual frequency response with REW, the Umik-1 mic costs $79 plus shipping, you will need that if you don't have one yet.
That's generally true when no dsp functions are involved, with dsp in use, there will be audible differences, from subtle to the so called night and day kinds, it depends..
As soon as you started comparing with DSP in use, and even with Audyssey then it gets complicated and personal preference will start to dominate. For example, what you consider as bass heavy could be just fantastic for others. So on that, I would just wait and see what others have to say, as for me, once it gets into the subjective territory, there is nothing for me to say that could be helpful at all.
Just replaced my Marantz SR6007 because the input board didn't work anymore with a Denon X3800h Because it seemed an affordable option at 790 euro (777 german euros) and I never liked the small Maranz circular display. Both were used with the onboard amplifiers and no room correction yet. Cats don't like the setup noises and not enough time in a day. I tried Audyssey with the Marantz but didn't like the end result, so left it off.
I listened to some music and a film maybe a bit more low but not that I noticed it. Setup screens have hugely improved and the HEOS app works alright. No problems playing flac from the raspberry pi (via minidlnad) Speaker setup is still the same two large fronts, no sub because they go low enough and two bookshelf surrounds. No idea what to do with all the leftover channels. It didn't come with Dirac that seems an expensive option.
Did read the original review from Amir but forgotten about it until after ordering
Earc works but that really old hdmi cable needed replacing. Standards have changed not all hdmi cables are the same.
I bought the 3800 after using a 4400 and a 4500. I could not get the 3800 to sound right to me no matter what settings I applied. I was disappointed because all the changed was the reciever with the exact Audessy settings i had before. I also have a lot of 5.1 dts music I listen to. I couldn't really explain or meaure the difference between the two amps. I gave up on the 3800 because I didnt not want to invest another 900 into the Dirac suite. I dont doubt that it very well could have been a setting but I was super happy to return my 4500 to service.
There is one more option but it's a little costly: since you already have the base Dirac license for the 3800, you only need to pay for the ART upgrade (DLBC is not required since you don't have a SW). It may cost you a little more but I hear only good things for ART users. Have you considered this?Thread resurrection.
I did not have the time to deal with my 3800 and set it aside until Dirac ART arrived, which is when I thought I would give it another try. This was also encouraged by having found a setting for applying -10 dB on the LFE in DTS which turned out to be unhelpful as it is either limited to vanilla DTS or has absolutely no perceptible effect on the sound ("tested" by ear with DTS-HD). ART did not help either, with or without a subwoofer.
I think I may have an idea why I seem to be the odd one out when it comes to the subjective music listening experience. Most of my collection is in surround using Dolby Amtos, DTS-HD, etc. formats. It really does sound horrible when there is any bottom-end action going on. The bass-heaviness doesn't really bother me in movies most of the time which is where most users would interact with such formats. Typical music listening would be done using 2 channel LPCM which is fine to my ears.
Could it be that Denon messed up how the LFE channel is handled in non-PCM formats? How would one go about testing this? Are there any sweep test files available, e.g. in DTS-HD and could they be somehow integrated into REW measurements?
I also think ART would help a lot of people but probably not the OP is he even found Dirac Live "not listenable". It would also cost him $300 right, and that is not recoverable/returnable. It is too bad that, as we both know it is very difficult if even possible to convince someone to do a blind listening comparison test as there are time/effort requirement and the need to have a favored unit to compare. Otherwise, even a single blind test will very likely make a lot of those perceived sound quality issues disappear, just ask Dr. Olive and/or Dr. Toole and hear what they have to say. The thing is, if we compare the specs and measurements of the 3600 and 3800, there is really nothing much to indicate the two would have such obvious differences in sound quality not only in direct mode but also in standard surround sound formats, so it just seems very weird that his perceived difference has to do with the hardware.There is one more option but it's a little costly: since you already have the base Dirac license for the 3800, you only need to pay for the ART upgrade (DLBC is not required since you don't have a SW). It may cost you a little more but I hear only good things for ART users. Have you considered this?
My gut instinct was some sort of user or hardware error. How often have folks messed up their calibrations by using the wrong mic or calibration file?I also think ART would help a lot of people but probably not the OP is he even found Dirac Live "not listenable". It would also cost him $300 right, and that is not recoverable/returnable. It is too bad that, as we both know it is very difficult if even possible to convince someone to do a blind listening comparison test as there are time/effort requirement and the need to have a favored unit to compare. Otherwise, even a single blind test will very likely make a lot of those perceived sound quality issues disappear, just ask Dr. Olive and/or Dr. Toole and hear what they have to say. The thing is, if we compare the specs and measurements of the 3600 and 3800, there is really nothing much to indicate the two would have such obvious differences in sound quality not only in direct mode but also in standard surround sound formats, so it just seems very weird that his perceived difference has to do with the hardware.
Perhaps I am a lesser man than you are but I would never ever even consider engaging in the "out-of-the-box" threads.The OP keeps saying his AVRs sounded different 'out of the box'. So forget about Audyssey, Dirac etc, stop suggesting other DSP! It's not on by default.
That leaves just : unboxing , plugging in, connecting the speakers, turning AVR on, then telling the AVR how many speakers are connected -- the OP indicates it's a surround setup so I assume theres x speakers and a least one subwoofer -- and that's it. Anything else that's user set -- like crossovers (speakers size) , distances, EQ, etc , is 'extra', which could be causing the perceived extra bassiness if its different between two AVRs. Any default settings with multiple options, if they different default settings in the two AVRs, also qualify.
The Denon 3800 simply IS NOT inherently 'bass heavy' (if the comparison is level matched), and most certainly not compared to other Denons.
This sounds like classic sighted listening phenom to me, or else just a simple setting issue, but the OP has a long way to go before he isolates the issue, if it's real. A lot more describing to do of exactly what he has and has not got active in the system.
I despair at how here on ASR still don't get the concept of reducing variables to one: the true cause.
tl;dr: he's doing something wrong, and ASR is off on tangents.
