tartalatruffe
- Joined
- Jul 15, 2022
- Messages
- 11
- Likes
- 1
Hi all! I'm questioning myself but I don't have sufficient knowledges about CD players, I'm sure some of you can help me to understand that deeper
What are the differences between playing CD into a standalone CD player VS into a 5,25" internal CD player put into a computer?
-Signal is supposed to be transported the same way to the DAC?
-Maybe with the internal CD player, the signal have a longer path, so it have more chances to add interferences to the digital signal (which will then need a stronger checksum); or even have to pass through the internal OS mixer?
-Maybe the power supply of a computer act differently than a power supply on a CD Player?
-Maybe a computer during CD playing is more noisy?
I'm planning on building a HTPC that can read everything and be cheaper than a Universal Disc Player (minus the ability to play Dolby Vision and SACD). But I want to be sure I'll get the same performance while playing CDs (which is a thing I still do often).
P.S. : I'm just talking about the CD player because in any case, it'll be connected to a high quality DAC (Toslink for the dedicated CD player, USB for the computer CD player), and to high quality speakers.
