nycarrival
- Joined
- Jan 9, 2021
- Messages
- 37
- Likes
- 1
Hello all,
I need some help and guidance.
I opened my Aeon 2 Closed and plugged them into my MacBook Pro. I will be honest - I have tried before using Topping DX3 Pro with Senheiser HD 600, but I did not quite experienced much difference from just using my laptop.
I liked teh sound of my new Aeon 2 Closed however it feels like I am not getting much power from my MacBook and I am reaching out to check if you can recommend some device I can get. Is the answer simply an AMP (providing my ears cannot make much difference) or get a combo DAC/AMP.
I will appreciate some recommendations on specific models I can consider. I was thinking about getting the new Topping DX 7 Pro, but thought it may be too much of an overkill for me.
Thanks in advance!
Thanks in advance!
