Any suggestions are welcome. Post suggestions here. I will gather the details and add them. Thanks. This will be organized as results come in.
For EQ Software for Windows, Linux, macOS, iOS/iPadOS and Android go here.
Good reference literature on crossovers:
Phase, Time and Distortion in Loudspeakers.
Thoughts About Crossovers.
Windows
For applying created filters:
Hang Loose Convolver (HLC) is a specially designed stereo and multichannel convolver to compare “level matched” convolution filters in real time with “instant switching” between filters.
EKIO a Loudspeaker Management Application, create a crossover for your full-range speakers, integrate a subwoofer and equalize the system.
dePhonica supports any Windows compatible soundcard.
Equalizer APO is EQ/PEQ and crossover software also has functionality to be a convolver for FIR-filters and has VST support.
Digital Room Correction Designer for creating room correction filters, playing music through the filters, Simple Automated IR Measuring Tool.
This form that is a guide with some scripts and guides for using Digital Room Correction Designer.
CamillaDSP cross-platform IIR and FIR engine for crossovers, room correction etc.
JRiver Media Center supports crossovers for Windows, macOS, and Linux with up to 32 channels of DSP. Besides its own filters, it also supports convolution filters from Audiolense, Acourate, RePhase, and DRC with automatic sample rate matching. It supports VST2 and VST3 plugins. For Windows it can be setup as an audio device so all Windows sound is routed through JRiver Media Center's DSP. It can also accept external audio via ASIO for processing.
Gaffel tool that splits audio into different frequency bands. Use it on multiple channels, use your favorite plugins as multiband effects. The different crossover frequencies are globally synchronized.
Focus Fidelity. This is new software and features are still being added. For now, no crossover generation. Windows and MacOS.
Multi-Sub Optimizer. Bass frequencies only. Can not be used for overall filter generation. Must be used in conjunction with REW. Windows only.
Audio Weaver. Very powerful, but also difficult to use. More of a development tool for engineers. Windows only. The penultimate tool for masochists, only beaten by:
Maths packages like Matlab or Octave. Requires manually entering equations, but anything can be done - as long as you know the equation. The ultimate tool for masochists.
For creating filters:
Audiolense a state of the art solution for digital crossovers, frequency correction and true time domain correction.
Acourate and AcourateConvolver includes all functions required for generating audio filters of the highest quality.
rePhase a free FIR generation tool for building fully linear-phase active crossovers with arbitrary slopes.
DRC generates the FIR correction filters.
Signalyst HQPlayer. Used by most to perform upsampling, but it can be used as a convolver. Windows, Mac, and Linux.
Acourate Convolver. Can only be used with Acourate due to requirement of .CPV files that Acourate produces. Windows only.
Plugins host:
Kushview Element acts similarly to a mixing board in a DAW by hosting VST, VST3, AXX, AU plugins with an easily understandable GUI. Within it you can host additional plugins like:
Linux
Pulseaudio Crossover Rack to design/implement crossovers w/ linux computer w/ a multi-channel sound card and using Pulseaudio.
ConvolverVST is a convolution plug-in.
VSTHost for loading VST Effects (also called "plugins").
Plugins host:
Kushview Element (Download here.)acts similarly to a mixing board in a DAW by hosting VST, VST3, AXX, AU plugins with an easily understandable GUI. Within it you can host additional plugins like:
macOS
AU Lab is a free digital mixing application that hosts Audio Unit effects and that ships with the Apple Developer tools.
Plugins host:
Windows
Plugins host:
- X-MCFX: multichannel .wav plugin THIS IS THE XO PART
- Sir3: reverb convolution known for zero latency and good updates across OSs. There are free options out there like MConvoltionEZ & XvolverEssential
- TDR Nova: great low latency parametric EQ with compressor/expander. Other free EQ options are MEqualizer, QRange, Marvel GEQ, Toned.
- Voxengo Sound Delay: for setting individual delay for drivers/subs
Linux
Plugins host:
macOS
Plugins host:
- Pro-Q3 for Crossover with Convology XT for FIR.
