It depends on your own expectations and how far down you want the "cardioid-like" frequency range to go.are there any realistic 'driver based' cardioid designs that doesn't involve a dipole and an omni-directional speaker?
....Note that the real mid-band sensitivity is more like 96-97dB/2.83V@1m. Eminence computes the average over the "usable frequency range", so in this case the Deltalite's rising response inflates the figure.
(Re: Deltalite 2512)
It requires a little massaging above 800Hz, but this is easy to do with DSP. If using a passive crossover a different driver may be a better choice. Note that the real mid-band sensitivity is more like 96-97dB/2.83V@1m. Eminence computes the average over the "usable frequency range", so in this case the Deltalite's rising response inflates the figure.
I haven't made any raw drivers, but I do (manual) room correction with my DSP software, which has full parametric EQ and FIR capabilities. I also designed and built a 4-channel poweramp to use with these speakers (see attached pictures). It uses the LM3886 chip, but is a bit different than most chip amps in that it has balanced inputs. The LM3886 is configured as a difference amp with NE5532 input buffers (basic instrumentation amp topology). Full KiCad design files, including gerbers are available here.>personal crossover software and waveguided loudspeaker
Now you only need to make your own drivers, amplifiers and room correction software!
Yes, half space (2pi) is how drive unit sensitivity is usually specified.Make that 2Pi sensitivity.
I don't know for sure since I haven't seen many good 3rd-party measurements of drivers of this type. One of the Kapplites may be slightly better. B&C has some good offerings too, but they tend to be a bit expensive (in the US, at least).What midbass driver would you suggest in its place?
