- Joined
- May 24, 2016
- Messages
- 644
- Likes
- 2,412
@dominikz very nice. Can you share the Correction Procedure Designer settings you used for Audiolense? Depending on what settings you used will have a major impact on the (measured and listening) results in the same way one can vary the target curve and hear significant differences. This is the advantage Audiolense and Acourate (and the open source DRC) have over other DRC products that don't have this capability. However, it takes time to understand what the settings control and how that translates into what one hears as it can have a significant impact on the sound quality.
With respect to single point versus multi-point measurements, one should take into consideration how each DRC product is "designed" to work. For example: https://www.audiosciencereview.com/...-altitude-jbl-sdp-75.13095/page-9#post-621360
To illustrate a bit, at least in the frequency domain, here is a direct loopback measurement through JRiver of Dirac's correction filter used in this article on top. On bottom is another DRC product using a FIR correction filter for the same speaker (both left channel). I drew a red line just above the FIR correction filter as I know that is 0 dBFS as I can inspect the FIR filter directly and measure it's peak amplitude (and group delay) in another application.
Note that the Dirac Live correction ontop was using 17 measurement points and the mystery DSP using a single point measurement on the bottom. As I can't inspect the Dirac correction filter directly, or know what is going on in the DiracLiveProcessor (i.e. is it "just" a convolution engine or is there additional processing?) it is difficult to draw any real conclusions. The only conclusion I can draw is that the two filters are going to sound different.
If we turn our attention to the time domain, I see you have some step response comparisons, but your horizontal scale only goes out to about 7ms or so. While that is great to show the time alignment capabilities it is missing the raison d'etre of DRC, which is being able to smooth out the bass response over time. This is what what the low frequency excess phase correction is designed for and one of the "key" differences between these DRC products (i.e. most don't have it). For example, in my system here is the step response, but over a much longer time frame:
Aside from the time alignment, we see no low frequency room reflections interfering with the "ideal" minimum phase response over a long time frame. Looking at the corresponding frequency response:
To me, this is the ultimate test of any DRC product. Drop a mic at your listening position and use REW's default 500ms window with no smoothing and the correction filter in circuit. (PS. and it is just not at one mic location as I have other posts on ASR that show the same results using 14 measurements over a 6ft x 2ft grid area). Let all the reflections in As we can see, below the room's transition frequency, there are no low frequency room reflections getting into the measurement (or technically achieving the ideal minimum phase response). Not only is the low frequency response smooth, but it is crystal clear. This is the major differentiator. Based on the number of systems I have received measurements for, I don't think many folks have really heard what clear bass over time sounds like. This to me is the deciding factor on how good a DRC is at "room eq". Aside from the clarity of the bass, it does not sound "overcorrected" as described in the Trinnov link posted above.
Again, good comparison, but I think you are just scratching the surface wrt tools like Audiolense (and Acourate and like @dasdoing mentions DRC) can achieve. You should be getting results similar to what I show above and in this article on what is accurate sound.
Keep up the good work!
