- Joined
- Jan 23, 2020
- Messages
- 4,511
- Likes
- 7,117
Yes, that's why it is often better to EQ for a linear direct sound instead of a predefined target curve above transition frequency.
I've honestly never tried this, but it makes sense. Are you using a collection of gated responses? I'm pretty confident that the 8351s already have a linear direct sound, so I'm not sure how necessary it would really be. I'm not even sure what Dirac does above the transition frequency, but I know it has 3 different frequency zones(at least) for which it uses very different EQ strategies. The frequency responses of Dirac full range vs limited range correction (using MMM) are identical above 1kHz. It takes 5 seconds or so to switch between profiles with my DDRC88A, and with that switch time, it's really difficult to hear any difference at all, if there is even any.
But Dirac is a bad solution for the home, since it only gives the user a bare tool, without understanding how to use it correctly. The client is forced to change the frequency response curve at random and search for info on the Internet
