Chord DAVE measured by Cosmos ADC
BlinkDL
Hi guys. I measured my Chord DAVE using Cosmos ADC (grade A). Cosmos is set to 4.5Vrms in both XLR and RCA measurements.
Note DAVE has a HF filter which affects the FR and probably cause the rise of IMD after 18kHz. I will remeasure it later without HF filter.
DAVE has higher noise and crosstalk than D90SE, but comparable THD.
XLR (higher noise due to opamps):
RCA (better performance but higher 2nd HD):
XLR details:
RCA details:
Although I mainly use DAVE for my PSI A17, its headphone output is especially good for IEMs. I find Monarch MKii a great match (no EQ needed :) this is very rare).
Here is a low imp. IEM (Senn M2I = 18ohm, good for testing because of its low unit-to-unit variations) at -13dBFS (Cosmos set to 1.7Vrms). Very clean HDs.
Note some of the noises are from the Cosmos earphone adaptor board (I am in a RF-noisy room today). This is what I get from just the board + earphone (adaptor unplugged from DAC):
I tested the unloaded Cosmos before and it doesn't have these noises:
Welcome to ASR. Very nice!
Something is wrong as you got better result using RCA than XLR.
Also, did you limited 40~15kHz (that's nothing) because the IMD from 18kHz ?
XLR has another opamp/gain stage/leg (+ and -) so will always have more residual noise. Its only benefit is immunity to intererence (hum and noise) in the cable, not the device itself.
