Cheap Headphone Hangers?
Berwhale
I noticed these wall mounted guitar hangers on Amazon and it occurred to me that could also be used to hang headphones.
solderdude
The Neitherlands
a 2-pack for £9.- (€ 11.-)
Would have to be wall mounted though and be easy to create a wall of fame with those.
Andretti60
San Francisco Bay
I don’t hang my headphones, they collect dust and you put stress on the headband. I close them, flat, in a drawer. Except for the cheap headset that I use for work (that for me doesn’t count as headphones)
Doodski
I never hang mine too. I set them down for 3 or 4 minutes and then put them back on...lol. I am strapped in most of the time. :D
Doodski
oh helll yes
Yes, I agree. I use those clips for so many things. They are ingenious and simple. One use is I hold all my credit cards and whatever cards that I carry together in one tight bundle with one. It's compact and I have never had a wardrobe failure using one this way.
Berwhale
Berwhale
I found these that work well, providing you have a horizontal surface to mount them to. Like the rounded profile to spread out the load on the headband.
https://www.amazon.ca/gp/product/B08S3GDGV5/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
Yeah, I have something similar, but without the wood, to hold my HD660s under my desk, in front of my PC...
I bought this one because it can be rotated out of the way .
D00M
I just bought these: The Anchor Pro $15 on Amazon.
Not the cheapest. Fit 2 headphones. I like that the hooks are wide, which spread out the force on the headband. I did use screw for the mount. I am doubtful that the VHB adhesive will hold over time.
My desk has a side cabinet. So I installed the hook inside the cabinet. This will prevent dust. And my cats cannot get to the headphones or cables.
I plan to buy another one so I can hang 4 headphones.
