Trell
- Joined
- May 13, 2021
- Messages
- 2,751
- Likes
- 3,359
unless i understood the literature below incorrectly, the Chrono SL 8 does not have passive crossovers as they have no more purpose in such implementation. the entire system is DSP contolled typical of this active speaker design.
At first glance, the approximately 100 centimeter high Chrono SL 8 looks like normal floorstanding loudspeakers, but the interior of the elegant and high-quality loudspeaker housing contains the very finest modern technology. A high-quality amplifier unit consisting of four individual output stages with a total output of 350 watts supplies the four individual drivers of each individual SL8 with sufficient power and makes an external integrated amplifier superfluous. In addition, a high-performance signal processor also functions as a phase-neutral crossover network and, thanks to active equalization of all drivers, ensures optimal acoustic performance of the 3-way bass reflex loudspeaker. A multitude of analog and digital inputs on both speakers of the stereo combination SL8 allows the connection of various sources, Of course, the Chrono SL8 also accept wireless music playback from a tablet PC or smartphone via Bluetooth. Since both SL8s communicate with each other using Canton’s own wireless network, they only need to be connected to one of the two loudspeakers. The extremely low latency of this radio transmission guarantees maximum precision and saves additional signal or loudspeaker cables.
https://www.canton.de/en/products/hifi/chrono-sl-series/smart-chrono-sl-8?number=04112
>>>The Smart Chrono SL 8 not only impresses with its neat appearance, it also delivers excellent sound performance in all situations. This is ensured by the precisely tuned Class D amplifiers with 350 watts of power per speaker, the two long-throw woofers with 160 mm double-cone titanium cones, the 160 mm mid-range specialist with wave surround and the fine-resolution tweeter with 25 mm aluminium oxyceramic. This quartet of loudspeakers operates in a very solidly constructed cabinet with internal bracing and strategically placed damping material, which ensures optimal resonance. <<<
The speakers are delivered in a master/slave configuration and from the description they are powered speakers.
