Peter Verbeek
So that isn't a problem as it's static data.There are cases where you benefit by dynamic adjustment - e.g. head tracking for spatializing algorithms - and this can meaningfully improve subjective experience, but for frequency response correction, a static equalization may be applied.
In test interface I've used the equal loudness contour ISO 226:2006. A user can select a Phon (0 to 100) to compare his test results against. From some experimenting the 60 Phon seemed to produce the best eq as the 0 Phon, the hearing treshold, producted too much bass in the resulting created eq. As I don't have any knowledge in this field I don't understand this. A better equal loudness contour could certainly help. Somehow the best results of the equal loudness contour is in the middle section of our hearing. Perhaps the equal loudness contour doesn't take headphones into account as shown in the image of figure 17. Then again I don't know how the measurements were done for creating the equal loudness contour of IS0 226:2006.Specifically, my recommendation would be using a diffuse field equal loudness - either a directly sourced one from the lit (there's one somewhere in the ISO standards, I believe, maybe even the same work as the FF equal loudness), or by applying the delta of FF > DF HRTF to the FF equal loudness (although this may have issues, due to the aforementioned influence of perceived acoustic source position) - and, following the work of Olive, Welti, McMullin, and Khansaripour, applying a generally "downward sloping" adjustment.
Anyway, if I offer all kinds of different equal loudness contours users might be lost. Somehow we need to come up with only a few which users can use. For advanced users there can be more like in different types. Also as this isn't my expertise I've a hard understanding it all. It's difficult to extract a test interface from all these different ways at looking at the research of the human hearing and their results such as the equal loudness contour. I'm sorry for my lack in knowledge and understanding.
That would be the explanation why the 0 Phon lacks result into an eq lacking enough bass. I guess doing a test with speakers in ones room would result into an eq (0 Phon based) with more bass. I'm speculating of course. Yes, such curves as shown in figure 16 can be used by the user to introduce more more/less bass and/or treble in the resulting eq.You could allow listeners to adjust a "slope" parameter (e.g. the stylized form of the original Harman adjustments from 2009 are 1dB/octave from 20-20000hz), give listeners the obligatory two 2nd order shelf filters at 105 and 2500hz from the linked paper, or directly apply the average preferred adjustments from said filters that Olive, Welti, and McMullin found:
In the current version I've already included notes for adjusting the resulting eq (on the interface and in the manual). You're entirely right that this is needed. Perhaps I'll take another look at these notes.so I would encourage you to include a note suggesting that users adjust the result
