As promised, here is my build of the Rick Craig’s new DIY speaker called Integrity. It was designed as a tribute to Jeff Bagby so emulates his design values. The kit parts are a pretty reasonable $600 for a 3-way passive radiator design. The midrange, tweeter and PR are SB Acoustics and the woofer is a Dayton ES180TiA. I was already working with the ES180 and wanted to do a 3-way design, so was naturally interested in the Integrity. Am planning to downsize in the next few years and a compact bookshelf with good low bass also appealed to me.
The Integrity cabinet is 18” x 8.5” x 11”. It is a fairly simple cabinet, but has a couple of challenges. One is recessing the truncated midrange and the other is the PR cutout. I will address the PR cutout during the build. As for the midrange, Rick indicates that flush mounting is acceptable. However, this unit is getting Klippel test scrutiny, so he supplied a pre-cut front baffle to me. I was able to complete the rest of the cabinet with a piece of 2’ x 4’ x .75” MDF. This is about as big a board as like to handle on my table saw. The Integrity panels are sized to be foolproof. All opposing panels are the same dimensions. The center brace is also the same size as the top and bottom panels. See attachments for details (added after initial thread post).
To start, I took the MDF and crosscut it to 25.5” wide. This piece can then be ripped 9.5“ wide on each side to create 2 panels. Each of these panels can be crosscut at 18” to create the side panels. The remaining parts are used to create the top and bottom. They are already 9.5“ deep, so they just need to be trimmed slightly to 7” widths. The remaining panels, can be cut from the other half of the original MDF board. In my case, I need the back panel early, so I cut a 8.5“ x 18” section from the remaining board. You should have enough wood remaining to cut the midrange enclosure pieces. This is another panel just like the top, so can use it as a pattern. The midrange enclosure back is 7” x 7.125“.
At this point, you should do a dry fit of the cabinet to ensure the panels are correct and fit well. It is best to do this on a softer flat surface to avoid damaging parts if they fall over. Use the attached side view as a guide. NOTE: you will get the best results if the top, bottom and brace are square and sized to fit. If the outside joints are not smooth, trimming these pieces equally will save work later and produce a better cabinet.
You are now ready to start gluing. Take one of the sides and lay it on a flat surface. I use the top of my table saw. TIP: before applying glue, be sure to lightly sand the mating surfaces. Applying wood glue to the inside length (18" part) of the back panel attach to the edge of the side panel. Clamp lightly until glue sets. It should look this...
