- Joined
- Feb 4, 2020
- Messages
- 194
- Likes
- 445
Thanks for helping make this happen. I'll test the speaker and ship it to Amir next week.
How is the Duratex coating? The top of front baffle got some hair like stuff, is it because of the brushing method? What finishing do most people do with their speaker?
Now we can wire up the drivers and do some acceptance testing. If you did not catch when wiring the crossover, both the midrange and tweeter are supposed to be wired in reverse polarity. Also, remember to ensure wire holes for the smaller drivers are sealed well. Put the passive radiator on last, but before you do, Rick specs a bit of poly-fill behind the woofer and behind the PR.
Now I do my usual measurements to verify the build (NOTE these are a bit preliminary at this stage). According to my multimeter, the DCR is a healthy 7 ohms. Next lets look at the impedance and phase...
Looks pretty good (and is very comparable to Rick's prototype). This is a solid 6-8 ohm design without any major phase issues, so should be an easy amplifier load. Resonances also appear to be well-controlled as the curves are quite smooth too.
Moving on to a frequency response measurement. This was done at REW 75 dB reference level, gated, on-axis at a distance of 30 inches with 1/12 smoothing...
For the purposes of this exercise, all appears functioning nominally. Since gating took out the response measurement below 300 Hz, I will add the the f3 for this design is in the mid 30s. No complaints about the bass from me. More in my listening tests. I did notice that I had to crank up my amp a bit more than usual to get the 75 reference level. Rick confirmed that he traded off some sensitivity for lower bass. He says it is about 82 dB. He will provide better and more detailed measurements later, so do not read too much into my crude ones just yet.
Thank you for detailed respond. I was wondering why the front baffle looked like that but the top and back were smoother. If you don't like the gaps, have you tried wood filler? I don't know much about it but guess it should have similar property to wood, so should be able to paint or veneer on it.Lol, Duratex is a textured paint...
What you see (although somewhat distorted by camera angle) is the finish you get applying Duratex with a standard roller. It could be brushed to have a grainy appearance but not worth it for this speaker. The default finish is much like pro equipment. This speaker is just getting some paint to protect it on the road. Without it, MDF tends to drink liquids and can deform badly if exposed to water.
Many DIYers either paint or veneer their speakers. Am not sure how popular Duratex is as a paint for home speakers, but most of my previous work used black spray paint. As my speakers go in a dark home theater, black is perfect for hiding them. I like Duratex better than spraying, but you have to like it’s textured look. In my experience, getting a nice finish is more work than any other part of building most speaker cabinets.
I filled gaps, sanded them thoroughly and used thick paint, but the seams still show more than I like.
Love it - great work, & congratulations. May I ask a super-nerdy question? What kind of glue did you use?
I use Titebond Premium for the initial glue joint and, after it dries, some Original to seal if needed. If am in a hurry, Titebond will set in about 20-30 minutes. Before I unclamp, I may add the additional glue to seal the joint better. So, can build most cabinets in less than a day, but they need a full 24 hour curing before stressing.
Often you will seal the exposed edges of mdf with light layer of wood glue or bondo resin. Otherwise they suck up moisture in he paint and expand.I filled gaps, sanded them thoroughly and used thick paint, but the seams still show more than I like.
Do those glue get back to liquid form if touch water or paint?Often you will seal the exposed edges of mdf with light layer of wood glue or bondo resin. Otherwise they suck up moisture in he paint and expand.
No not at all (wood glue would if you soaked it but not with painting). Use wood glue or fiberglass resin. They will be fine.Do those glue get back to liquid form if touch water or paint?
Hi, that baffle may help with diffraction. The difficulty is high, essentially you would want to be very experienced or have an experienced friend assisting the build.Thanks for presenting this. The Meniscus site shows photographs of a beautiful construction with radically beveled front baffle and a lovely rosewood veneer.
Any comment on the difficulty of doing that style of front baffle? Does it have any negative sonic effects?
Jack
