- Thread Starter
- #1,701
If you add a measurement that's at a different FFT size, it will not add it. That's because it will not fit on the same FFT display with differently sized results.I updated,yes.
I think I pinned down and has to do with scaling.
For example if the existing measurement is silence and I add a 1 Khz measurement just doesn't do it.
If the scale is similar is ok.
