- Joined
- Feb 23, 2016
- Messages
- 20,866
- Likes
- 37,872
Okay, the display glitch as posted in screen shots above. If I have both devices set for 48 khz, and upper frequency set for 20 khz. I can change the recording device to 192 khz and upper frequency set to 96,000 hz it runs fine. If I then highlight a portion with a center click and drag over just the frequency axis it shows what I highlighted. If I run it again after changing FFT size or sample rate the display scales with the changes. Hitting "reset axis" fixes this. So that makes some sense.
Now the other glitch. If I reset sample rates low like 48 khz or 44.1 khz, while leaving the upper frequency limit at 96 khz. It will run properly at all FFT sizes except 1 million. When set to 1 million it works up until it shows processing, and then closes. If I lower the upper frequency to anything lower than 96,000 hz even to just 88,200 hz it will work. But at 96 khz upper frequency limit or higher it closes. Now it makes no sense to set the upper frequency above what the chosen sample rate will record. It was just an accident I didn't remember to reset it. Maybe the upper frequency limit needs to check the recording device sample rate and not allow those higher settings.
