.wav 24/28 - In-room recording via Audacity using UMIK-1, exported to .wav, so probably 16/48 at that point.
The files are just under two minutes.
Restarted the app, changed trim to 0, reselected the files (opposite order)
Log:
2019-03-22 12:22:04.2965|INFO|Wave.WaveForm|DeltaWave 1.0.18.0 starting up
2019-03-22 12:22:04.3825|INFO|Wave.WaveForm|Adding driver: [ASIO] ASIO4ALL v2
2019-03-22 12:22:04.3825|INFO|Wave.WaveForm|Adding driver: [ASIO] miniDSP ASIO Driver
2019-03-22 12:22:04.3975|INFO|Wave.WaveForm|Adding driver: [ASIO] Topping USB Audio Device
2019-03-22 12:22:04.3975|INFO|Wave.WaveForm|Adding driver: [ASIO] UMC ASIO Driver
2019-03-22 12:22:04.4435|INFO|Wave.WaveForm|Adding driver: [WASAPI]{0.0.0.00000000}.{0a0b8dca-0be7-4dbf-b760-f53ab8fd8ba9} | [WASAPI] Speakers (2- TOPPING USB DAC) 48000/32
2019-03-22 12:22:04.4755|INFO|Wave.WaveForm|Adding driver: [WASAPI]{0.0.0.00000000}.{2ecd896b-6393-4e37-9b6e-a2d218958679} | [WASAPI] Speakers (Benchmark DAC2 USB Audio 2.0) 48000/32
2019-03-22 12:22:04.5055|INFO|Wave.WaveForm|Adding driver: [WASAPI]{0.0.0.00000000}.{818a5cd1-dc76-44fb-bf58-74b882a81dd3} | [WASAPI] Speakers (miniDSP 2x4n) 48000/32
2019-03-22 12:22:04.5425|INFO|Wave.WaveForm|Adding driver: [WASAPI]{0.0.0.00000000}.{d215e59e-a420-4909-ac70-7e03986f5581} | [WASAPI] LG TV-4 (NVIDIA High Definition Audio) 48000/32
2019-03-22 12:22:04.5975|INFO|Wave.WaveForm|Adding driver: [WASAPI]{0.0.0.00000000}.{f28658e1-6bcc-4f90-9221-1074ed35e888} | [WASAPI] Speakers (Realtek High Definition Audio) 44100/32
2019-03-22 12:22:04.6265|INFO|Wave.WaveForm|Adding driver: [WASAPI]{0.0.0.00000000}.{feec5e7e-cab0-4899-aa8b-42b3989d04b9} | [WASAPI] Speakers (DTS PlayFi Audio Renderer) 44100/32
2019-03-22 12:22:04.6315|INFO|Wave.WaveForm|Current driver: [WASAPI]{0.0.0.00000000}.{f28658e1-6bcc-4f90-9221-1074ed35e888}
2019-03-22 12:22:04.6765|INFO|Wave.WaveForm|Adding driver: [ASIO] ASIO4ALL v2
2019-03-22 12:22:04.6825|INFO|Wave.WaveForm|Adding driver: [ASIO] miniDSP ASIO Driver
2019-03-22 12:22:04.6825|INFO|Wave.WaveForm|Adding driver: [ASIO] Topping USB Audio Device
2019-03-22 12:22:04.6825|INFO|Wave.WaveForm|Adding driver: [ASIO] UMC ASIO Driver
2019-03-22 12:22:04.7165|INFO|Wave.WaveForm|Adding driver: [WASAPI]{0.0.0.00000000}.{0a0b8dca-0be7-4dbf-b760-f53ab8fd8ba9} | [WASAPI] Speakers (2- TOPPING USB DAC) 48000/32
2019-03-22 12:22:04.7445|INFO|Wave.WaveForm|Adding driver: [WASAPI]{0.0.0.00000000}.{2ecd896b-6393-4e37-9b6e-a2d218958679} | [WASAPI] Speakers (Benchmark DAC2 USB Audio 2.0) 48000/32
2019-03-22 12:22:04.7785|INFO|Wave.WaveForm|Adding driver: [WASAPI]{0.0.0.00000000}.{818a5cd1-dc76-44fb-bf58-74b882a81dd3} | [WASAPI] Speakers (miniDSP 2x4n) 48000/32
2019-03-22 12:22:04.8125|INFO|Wave.WaveForm|Adding driver: [WASAPI]{0.0.0.00000000}.{d215e59e-a420-4909-ac70-7e03986f5581} | [WASAPI] LG TV-4 (NVIDIA High Definition Audio) 48000/32
2019-03-22 12:22:04.8655|INFO|Wave.WaveForm|Adding driver: [WASAPI]{0.0.0.00000000}.{f28658e1-6bcc-4f90-9221-1074ed35e888} | [WASAPI] Speakers (Realtek High Definition Audio) 44100/32
2019-03-22 12:22:04.8935|INFO|Wave.WaveForm|Adding driver: [WASAPI]{0.0.0.00000000}.{feec5e7e-cab0-4899-aa8b-42b3989d04b9} | [WASAPI] Speakers (DTS PlayFi Audio Renderer) 44100/32
2019-03-22 12:22:04.8985|INFO|Wave.WaveForm|Current driver: [WASAPI]{0.0.0.00000000}.{f28658e1-6bcc-4f90-9221-1074ed35e888}
2019-03-22 12:22:07.4725|INFO|Wave.WaveForm|ProcessAll
2019-03-22 12:22:07.4985|ERROR|Wave.WaveForm|Failed to load file: D:\Temp\Frame2 audio.wav
Comment:
Trim:
It didn't like comparing that length when it initially did work, so I trimmed it. the complaint seemed to be related to some time difference.
The trim seems to want seconds from beginning and seconds from end. It would make more sense to me to specify a start point and a duration than a distance from each end (assuming that's how it works - seems to be).
Had to keep trimming the the end to get it to a size it would smunge without complaining about the size. Not sure how long that was. Let's see:
Start at +75, end at -35, 120 second file, so about 120 -35 = +85, so, about a ten second compare.
So that worked yesterday, until it didn't, several compares and app restarts later.
My first time trying the software, so you can blame me.
